Thoughts plz: broken clutch pics
Old May 26, 2010 | 08:34 AM
RedRenisis's Avatar
should i have it welded or trash it, my company works very closely with a machine shop, i know if i decide to have it fixed they'll do a good job, but i just don't know
Attached Thumbnails Thoughts plz: broken clutch pics-507-001.jpg   Thoughts plz: broken clutch pics-507-002.jpg   Thoughts plz: broken clutch pics-507-003.jpg
Old May 26, 2010 | 08:43 AM
RIWWP's Avatar
You can have it welded. But PLEASE PLEASE go here (http://www-odi.nhtsa.dot.gov/ivoq/index.cfm) and file a report on this with the NHTSA. We are trying to get Mazda's attention on the premature clutch pedal failures due to weak welds. There is an active investigation now, and this, plus pictures, will help add to that.
Main thread for this: https://www.rx8club.com/series-i-trouble-shooting-95/clutch-pedal-snap-off-8-year-warranty-recall-%7E%7E%7E-132912/
Old May 26, 2010 | 09:20 AM
syntheticdarkness's Avatar
ThEy MaDe Me Do It
Here is a thread that might help you with fixing it.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-clutch-pedal-bracket-removal-fix-170387/
Like RIWWP said, please report this.
Old May 26, 2010 | 01:24 PM
RedRenisis's Avatar
all welded up.. some pics
Attached Thumbnails Thoughts plz: broken clutch pics-507-004.jpg   Thoughts plz: broken clutch pics-507-005.jpg
Old May 26, 2010 | 01:36 PM
cornholio135's Avatar
SARX
I had mine welded and it started breaking again. an easy prevention for this is to either weld or bolt up a 90 degree bracket on the left side of the assembly where the top hole is.
Old May 26, 2010 | 01:44 PM
RedRenisis's Avatar
what time frame before is started breaking again, was it squeaky? he used a tig welder on it, ill soon find out if it works, gonna take the roads with the least traffic lights back and forth to work for a while
Old May 26, 2010 | 02:04 PM
SARX
Uhh maybe about a month or so???
here is a pic of a reinforment braket kit offered by a vendor here. Not that hard to make some brackets. but you get the idea.
Old May 27, 2010 | 10:37 AM
ThEy MaDe Me Do It
Mine was still going strong after a year, but since I drive really far, I ended up buying that bracket/new pedal. Check your springs in the top of the clutch pedal to make sure they aren't carving through the bracket also.
Old May 27, 2010 | 11:03 AM
ThEy MaDe Me Do It
I did a little mod on mine to make sure the spring does not dig through again. Got some stainless L brackets and drilled out the hole so it fit snug, then welded it.
Old May 27, 2010 | 11:22 AM
ThEy MaDe Me Do It
Lol. I ran into that also going through 3 hardware stores until I found something close enough. Can't wait to see it, keep me informed.
I am currently pursuing a fix for that, too, and one that takes about 30 seconds to install without removing the pedal. I may need to have the parts custom-made (like friggin' usual) as the sizes I need are quite evasive.
Old May 28, 2010 | 10:24 AM
RedRenisis's Avatar
thanks for the input guys, gonna buy the reinforce kit and new clutch in the near future, so Charles ill be in contact with you, only have a few more payments then she's all mine.
So I got the clutch pedal back in the car, hooked it up, seems to be working fine, however when i took ot for a test drive cause its been sitting for about a week, got home, popped the hood and start wiping it down, guess whats missing, my god damn tension pulley for the ac belt, i just saw a bolt hanging in there and was like ****, looked at an exploded view and sure enough 5 pulleys instead of six, I just had Mazda put new belts on cause im getting up there in mileage. IDk but they're fixing it, also found a blown coolant hose, if it aint one thing its another
Old May 28, 2010 | 11:09 AM
RedRenisis's Avatar
Pedal free-play set between 1/4"-1/2"?
yeah i checked it with calipers, but just to be sure im gonna have Mazda check it for me when they fix the other problems, at first when i drove it the cluctch was slipping and it wasnt making that chirping sound in neutral, adjusted the pedal a little, chirping came back, slightly pressed the clutch and it went away, this is how its always been drove it around the block clutch didnt slip but i really couldnt run it hard cause im nervous of my new findings, hopefully all will be well by tomorrow, so much for trying to save a buck
BTW do you recomend any coolant hose kits, probably gonna get an oem hose due to time constraints right now but on my wish list, as well as your mid-pipe, when will the upgrade be completed.
xAgyex
Jun 3, 2026 03:47 PM
Dokuji
Nov 1, 2016 02:51 PM
ribbon
Nov 24, 2015 09:21 PM
HMSS013
Aug 28, 2015 03:08 PM
RX7.9
Jul 20, 2015 12:01 PM
