RX8 at RedLine Time Attack
Old May 20, 2010 | 12:23 PM
RedlineTimeAttk's Avatar
Former Sponsor
Here is one of the RX8s at RedLine Time Attack:
Mazdatrix.com
Driver Name: Dave Lemon
Team City Location: Signal Hill, CA
Team Website: www.Mazdatrix.com
Vehicle Year, Make & Model: 2004 Mazda RX8
Engine Type and Size: 1308cc Supercharged 13B Renesis Rotary
Estimated Wheel Horsepower & Torque: 409HP
Estimated vehicle weight: 2700 lbs.
Brand and Model of Suspension: Apexi S1
Brand of Brake System: StopTech
Brand, Model and Size of Tires Used: Nitto 285x35x18” NT05
Class: Street RWD
Old May 20, 2010 | 12:24 PM
The Reverend's Avatar
That's a lie
Procharger
thanks for the pics there are some more of this car in one of the Formula D pics threads
Old May 20, 2010 | 12:40 PM
JinDesu's Avatar
went back to srsly broke
Woo! Lotta 7s at the RedLine Time Attack event. But the car to beat is that Sierra Evo 8
*er - unless it's in a different class :x
Easy_E1's Avatar
That looks familiar. Nice pics.
Old May 20, 2010 | 12:49 PM
Symbioticgenius's Avatar
You Dumbass!!!
Supercharger making 409 HP. Interesting.
Old May 20, 2010 | 01:14 PM
Chibana's Avatar
The Michigan "WANKEL"
I wish I could get that supercharger kit for my Series II RX-8. Maybe a few years down the road (when I would actually have the money for it, anyway).
Old May 20, 2010 | 01:48 PM
Mazdatrix's Avatar
Former Sponsor
See videos and pictures of the RX-8 at mazdatrix.com/mazdatrixracing
Old May 20, 2010 | 02:31 PM
Highway8's Avatar
Registered RX8 Nut
It should be the dna procharger kit. That intercooler looks just like the one sitting in my garage waiting to go in over the next month.
409HP? That has to be crank. On the 12PSI kit, when tuned right, with the headers and 3" exhaust and lightweight flywheel I can beleive it. However it wont make that much until almost 9K RPM's.
To mazdatrix, some info on the procharger? I dont like the airfilter size and location. Did you relocate or leave it in the original place? I moved my overflow bottle and I want to build a cold air intake box for the filter. Just something about starting with 200 deg air does not sit right with me.
Old May 20, 2010 | 02:49 PM
Highway8's Avatar
Registered RX8 Nut
Found some photos. Larger air filter, relocated the surge valve and the coolant bottle. Running water/meth injection? I would imagine you would have too. The intake temps must be high with the intake above the radiator. Given any thought to relocating the airfilter or building a box and cutting a hole to pull in air from outside the engine bay? Those are my plans, still might do the water/meth injection depending on my results.
Old May 20, 2010 | 10:56 PM
Mazdatrix's Avatar
Former Sponsor
There are a lot of "back stories" to the car ---
We decided to make my daily driver (bought it new in July '03) into a Time Attack car about 4 weeks (that is another story) before the first event. Redline was doing up "Hero Cards" right away and needed pictures and specs. We did the graphics on one side only, loaded the trunk with all the lead we had and put a bunch of flywheels in also to lower it. Positioned it with RF in a hole and put a 4x4 under the left rear -- came out looking like a race car.
We had not even started on the supercharger install and they wanted horsepower numbers! Always liked the sound of 409 from my early Beach Boys days - so that is what we told them. Maybe it made the other competitors worry? Sorry for the fudge. As of last Monday night we are at 301 with maybe 8 pounds of boost.
Yes, the kit started as the DNA one we had, but it has already gotten pretty far from the original kit. We were really hoping to "race what we sell". (At least all the suspension and brakes are "off the shelf" from here). On the track we right away had cooling and belt slipping problems. We cut 4" off the bottom of the intercooler and did a bunch of shrouding for the second event and it was much better but still too high on a long run. We just installed the billet impeller water pump and will find out at California Speedway on 5/29-30 if that is fixed.
Btw - We were kind of surprised that the oil temp has been fine all along with only the stock dual coolers!
With the original supercharger kit, and the belt slipping, it was only getting about 4 pounds at the first event (it was a mad thrash to get there!). The belt finally gave up 2 laps into the Super Session. We changed to a smaller pulley, and ran the belt a lot tighter for the second event, but it was still slipping and would stop gaining boost at ~5 pounds at 6500. We now have the NEXT smaller pulley and had both of them treated with an "anti-slip" rough stuff. Made a larger diameter idler and it now gains boost all the way to 9200, as it should.
We also had a problem with the piggy back that came with the kit not being able to control the injectors adequately. We installed a Haltech Sprint RE for the second event. After a few teething problems it is now working great. We were also running out of fuel with the stock injectors so we went to a pair of 900cc ones in the secondary. The fuel now works fine.
Yes, we relocated things in the engine bay and have a ducted carbon fiber hood. Built a shroud to keep some of the radiator heat from the filter and have a fresh air duct going to the filter. We are using a much larger K&N than what came with the kit. We will probably eventually cut the front up some to bring in more air -- but I just have not wanted to cut up MY CAR yet.
We ran a 50/50 water/meth mix (not enough fuel) at the first event, but have now gone to water only. Not sure if it's needed, but we wanted the safety factor. The engine is still bone stock and has never been apart.
It has been interesting, and fun so far. I am still in the points lead for Street Tire RWD!! Not sure if we can maintain that after the next event.
Dave Lemon,
Owner - Mazdatrix
Old May 20, 2010 | 11:29 PM
Brettus's Avatar
Boosted Kiwi
Cool - good to hear how you are progressing .
You should have gone for the accessport though .....
Old May 20, 2010 | 11:32 PM
Highway8's Avatar
Registered RX8 Nut
300HP on 8PSI is a good sign but I am kind of surprised about the belt slipping issues. I had done some reading about users of the kit overseas and no one reported any issues with the belt or cooling. Even when usd for racing. Maybe not raced as hard as you guys are running it though.
I plan to use an AEM intake for the intake tube and run it as a maf based system.
I will keep an eye on this project. Good luck.
Old May 25, 2010 | 12:55 PM
Highway8's Avatar
Registered RX8 Nut
Installing my DNA procharger kit this weekend. Again as mentioned as a blow through maf system, tuned by MM with the AP.
I looked into to the pulley coating and went ahead and sent my 12psi pulley to Carbinite Racing for their tungsten carbide coating. They said there is no need to coat the crank pulley because it is so much larger. When I spoke with Rob he asked what kind of vehicle I was using it on and when he heard he said they coated your pulleys.
Still trying to figure out the best way to make a fresh air intake.
Old May 25, 2010 | 06:47 PM
Former Sponsor
Come see this dude shred it up this weekend in Fontana. We have 14 of our 30 $100 off sponsorship spots left. Hit me up If you want more info.
Old May 28, 2010 | 07:05 PM
Former Sponsor
We have 8 spots left and we are splitting them in half! We are now doing 16 $50 off one day passes. If you wanna come both days we can combine 2 for you, but they are running out fast.
Deal only applies to those signing up over the next 24hours. Contact Brent@redlinetimeattack.com to sign up.
Old May 28, 2010 | 07:06 PM
Former Sponsor
Old May 30, 2010 | 12:14 PM
Nemesis8's Avatar
Bigus Rotus
Did you start a thread on your build?
Old Jun 9, 2010 | 10:03 PM
chiketkd's Avatar
Row faster, I hear banjos
How's development of your Time Attack car coming? Have you been able to hit higher boost levels on the kit? If so, what kinda whp & wtq numbers are you seeing?
F51
Aug 2, 2021 04:07 AM
BigMikeATL
May 26, 2016 12:31 AM
RX7.9
Jul 20, 2015 12:01 PM
Belalnabi
Jul 17, 2015 07:48 PM
