Air injection Opening on header?
Old May 19, 2010 | 09:31 AM
cody205's Avatar
GA Air injection Opening on header?
Okay, so I'm just getting into actually doing things to my rx, and I don't know much, but I AM trying to learn. I've used the search box religiously and came across many things, but I haven't seemed to find anything on my particular situation, so I'd like some flame-free help from some of the more experienced rotorheads out there. If it HAS been covered before, I haven't found it through searching, so I apologize. Please either go over it again, or provide me with a link to where I can help myself. Here we go...So the opening in the stock exhaust manifold is for the air injection tube. On the stock manifold it has two threaded pins sticking out, which are placed through the holes on the air injection tube, then tightened down with nuts. On my aftermarket header, I just have two threaded holes. I believe it is a fluid motorsports header. I assume it is NOT reccomended to block off the air injection tube? I have a 2004 na rx8 with a k&n typhoon intake, a cat-delete pipe, and this header. What should I do about this, and how should I go about doing it? Should I block it off, should I......?
Here is a link of the opening I am talking about(In this link, it also has the pins with nuts, as the stock manifold does, except this one is blocked off)
http://www.racingbeat.com/Mazda-Perf...rtNumber=16346
Last edited by cody205; May 19, 2010 at 09:32 AM. Reason: added link to picture of what I'm talking about.
Old May 19, 2010 | 10:44 AM
zoom44's Avatar
where do you live? are you driving this car on the street or will it be a track car?
Old May 19, 2010 | 10:50 AM
czar's Avatar
Almost boosted
the air injection is to speed up the cat warm up, it runs at start up then shuts off, it wont hurt anything besides emissions. It also wont pass inspection though with a cat delete.
Old May 19, 2010 | 11:17 AM
Greenblurr93's Avatar
Sotally Tober
If you dont have a cat, you can make a block off plate and remove the pipe and secondary air pump and solenoid as its not needed anymore...
you will throw a CEL for it though.. you can disable it as well as the cat CEL with the Cobb AP
Old May 20, 2010 | 08:29 AM
olddragger's Avatar
why not make that little extra exhaust flow into another header pipe?
Old May 20, 2010 | 08:41 AM
Sotally Tober
could make one of those wastegate style dump tubes and have it come out the bumper like those cool kids...
Old May 20, 2010 | 09:45 AM
supergoat's Avatar
I don't "smell good".
Let me get this straight. The air injection tube has two holes. The header has two threaded holes.
Why not just buy some bolts that thread into those holes so you can connect the air tube to it? Problem solved.
Old May 20, 2010 | 09:58 AM
Easy_E1's Avatar
Just block it off like in the racing beat header pic. You don't have a cat. You don't need the airpump. (because you have no cat)
And it's an inlet not an outlet Olddragger.
Old May 20, 2010 | 12:13 PM
olddragger's Avatar
what goes in can come out
Just curious
Old May 20, 2010 | 04:17 PM
olddragger's Avatar
I wonder if anyone has uncovered it and ran the engine?
Besides if you put a pipe there you could also have a small john deere lawnmover muffler on it--let it hang down--swear by it and next thing you know 2-3 others would do the same---and it would run like a deere !
OD
Old May 20, 2010 | 07:02 PM
TrochoidMagic's Avatar
is adjusting valve lash
didn't look at the link... but i feel you.
you don't gotta be a genius to solve that problem... as i had no spare 10mm bolts with the proper thread reach when i installed MY header (same problem).
use the phillips head screws off your front license plate. they are easier to align to the gasket when installing. they only need to be handtightened, but feel free to replace with 10mm bolts afterwards that has proper thread reach.
such an easy problem to tackle...makes me wonder why you post for help if you've gone that far on a header install???
Old Jun 18, 2010 | 06:47 PM
cody205's Avatar
GA
I can haz ADHD? I jump into things without completely knowing what is necessary to complete everything. I know... BAD Ju-ju. BUT, I'm ALWAYS learning from my mistakes!!!
Old Jun 18, 2010 | 06:51 PM
cody205's Avatar
GA
I can haz directions to remove air pump and solenoid?
Do I need a different belt, or anything else except to remove the pump and solenoid? Where is the solenoid? I see the pump.
Old Jun 18, 2010 | 07:07 PM
Jon316G's Avatar
Grasshopper
What is with 'I can haz'?
Try 'May I have' . . . damn kids
No... the air pump is electrical, not belt driven.
Behind the UIM, in front of the oil filter, top solenoid with a blue connector.
Simply disconnecting the electrical connection will prevent the valve from opening, no need to remove the whole solenoid.
I see the pump.
You can remove the pump itself, but not everything on that "bracket".
It also has a fuel resistor and sensor that will prevent the car from running if removed.
Old Jun 18, 2010 | 07:17 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Oh boy.......not talking about this instance, but over all........this is probably not going to end well.
Old Jun 18, 2010 | 07:42 PM
cody205's Avatar
Lol. my wife changed my phone around. She does it from time to time, then sits back and watches as I make an *** out of myself online, or when I send emails to people with higher rank.(US Army) Sorry about that. Thank you for the directions. Helped out quite a bit. I am trying to learn all I can without learning from my OWN mistakes. BUT, I always end up to do so, in one way or another anyways.
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
jorx7
Sep 29, 2015 04:54 AM
