Car is POSESSED! Guages flicker with no key in ignition!
Old Apr 9, 2010 | 03:10 PM
jones75254's Avatar
Dont know if it matters but it was unusually cold last night (38 or so), go out to start the car (is garaged) this morning, turned the key and got absolutely nothing. The red key indicator light began to flicker in a weird sequence. I take the key OUT and the needles on all the guages start flickering back and forth rapidly. There is also a very faint backlight on all guages. A low tapping/flickering noise coming from the needles. They would not stop, i disconnected the negative battery terminal for a while, hoping that would stop them. I reconnected the terminal and the guages went all whacky again. WTF??? Anyone ever experience this or hear of it? Im at a ****** loss.
Old Apr 10, 2010 | 09:46 PM
dmazda's Avatar
Check your battery cables. That happened to me when the battery wasn't connected the right way.
Old Apr 10, 2010 | 09:55 PM
Vlaze's Avatar
The Angry Wheelchair
Your ground is corroding. Mine does this when I take the ground terminal off and place it back on w/out using the nut to do problem shooting issues. If I just hold it slightly on it, it will do this constantly. Make sure you securely tighten the ground down or clean it to get better connections. You should also hear a valve clicking sound constantly when this is happening.
delicious_dallan
Jan 17, 2020 09:17 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
madrotor
Jul 26, 2015 12:06 PM
dbarber
Jul 25, 2015 01:34 PM
