went a smidge over in oil?
Old Apr 7, 2010 | 02:03 PM
jenifer's Avatar
2006 RX8
Unhappy went a smidge over in oil?
I was just wondering I have a 2006 AT I went a lil over the feel line could this cause problem I'm not for sure I figure since they use oil it would be okay I need and opinion please!
Old Apr 7, 2010 | 02:25 PM
ambulanceonfire's Avatar
9k
If its only a small amount i wouldn't worry about it as the engine will use it. However if you over fill often it may cause problems with your ssv because of sucking oil up and into the intake. You could do yourself a favor and install a catch can to avoid that problem completely.
Old Apr 7, 2010 | 03:29 PM
invasion08's Avatar
You will be fine if you only a little bit over the full mark. How far over the full mark are you?
Old Apr 7, 2010 | 09:51 PM
jenifer's Avatar
2006 RX8
Like where the fill line is I went let's say if there was two more lines after the fill I did two lines over if there was lines
Old Apr 7, 2010 | 09:57 PM
I used to run 1 qt over for autox and never had any issue.
BTW this area is supposed to be for 2009+ RX-8 models
Old Apr 19, 2010 | 11:35 AM
Yep another usless thread in the wrong section.
Old Apr 19, 2010 | 11:42 AM
heyarnold69's Avatar
Rotary wanabee
I'm confused by this tread ...
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
