Help.. Scared =(
Old Apr 6, 2010 | 11:15 PM
b1gb4ng's Avatar
Help.. Scared =(
Ok recently when i turn on my car to warm up. My idle is at 2000 rpm. I was wondering if that is normal? or do i need to so something asap?
Old Apr 6, 2010 | 11:19 PM
Jon316G's Avatar
Grasshopper
Does it return to normal after a couple minutes (if that)?
Its common seeing that when the outside temps are low (like in the winter).
Also, did you just disconnect the battery for any reason?
Old Apr 6, 2010 | 11:23 PM
Kaka8's Avatar
ur engine was cold thats why..
Old Apr 6, 2010 | 11:28 PM
tza0001's Avatar
Dum Spiro Spero
+1! Normal
Old Apr 7, 2010 | 12:42 AM
RWatters's Avatar
It's normal.
You want to see a high idle then park it outside overnight in 5 degree weather. When I went out the next day to start it, it cranked over like a champ and went all the way up to nearly 3,000RPM for a moment or two before it started to come down.
Old Apr 7, 2010 | 06:00 AM
PeteInLongBeach's Avatar
I have read where there is an override / defeat of the cold high-idle on the RX-7, and wonder if this is true and if it works on the RX-8 also. IIRC, it involves starting the motor with the clutch pedal pushed in and the transmission in gear.
Old Apr 7, 2010 | 06:11 AM
BG-8's Avatar
The car won't start if you don't push the clutch in anyway, no power goes to the starter, it's a safety thing... and I always have my car in gear and release it after the engine turns over. So this won't matter, I still get the high rpms when I first start the engine when cold.
It is normal, but not normal if it stays at that high rpm...
Old Apr 8, 2010 | 10:10 AM
jasonrxeight's Avatar
it shoots up to higher rpm so the oil pressure would come up quicker so you dont damage the engine
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
Trekk
12
Sep 25, 2015 03:08 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
GrAfiX
Aug 24, 2015 08:08 AM
