Powersteering Question
Old Apr 6, 2010 | 09:35 PM
Fate710's Avatar
Super Low & Super Slow
This is for all the guys that have either swapped to a different rotary engine, or swapped to a whole new question all together.
I know the RX8 uses an electric assist pump vs a belt-driven pump and most of the swapped RX8s I've seen don't have the electric pump anymore. Are you guys converting to a mechanical pump, looping the lines and running without powersteering, swapping to different steering racks or what?
Old Apr 7, 2010 | 12:11 AM
dznutzuk's Avatar
Uncontrollable drifter
The guys with 3rotors are still using the electric rack, as am I(13bre). Works great!!!
Old Apr 7, 2010 | 12:19 AM
Fate710's Avatar
Ok you are still using the factory rack, but are you using the factory setup(i.e electric pump)? If so, can you post some pics of how you have it mounted now.
Old Apr 8, 2010 | 12:28 AM
dznutzuk's Avatar
Ummm, I haven't touched it at all, the setup is totally stock with it's wiring. All you need to do is install the front crank sensor and of course leave the stock computer still attached.
Old Apr 8, 2010 | 01:48 AM
Fate710's Avatar
Well I'm contemplating a couple of different swaps(mainly 13b-rew and LS1), and I'm trying to figure out if I can retain the stock power steering setup, or if I could just loop the lines and convert it to manual.
Old Apr 8, 2010 | 03:06 AM
not sure what you are asking.
the stock steering goes through the ecu.. it is electric..
if you are going to swap anything.. there you go...
it goes through the ecu..
if you swap motor..
get ready to lose. at least.. abs, dsc, radio, pretty much anything that uses the ecu.
or have lots of money, or a friend..
just saying.. simple and easy tends to be neither..
Old Apr 8, 2010 | 07:04 AM
dznutzuk's Avatar
Like swoope said, it's an electro-hydaraulic steering rack that's controlled by the ecu, since a stopped car, driving slow, and driving fast all require(not really all but) different adjustments. I kept the stock ecu and crank sensor and all the wiring and I still have everything mentioned above except for traction control(working on that soon)
Old Apr 8, 2010 | 11:31 AM
Fate710's Avatar
Ok then I just won't worry about the powersteering setup anymore then. Swaps are easy enough.
You move to factory RX8 engine harness out of the way but leave it intact so the factory RX8 CU still operates everything the way it should, and just run the harness and ECU for the other engine.
Old Apr 29, 2010 | 05:16 PM
NACer4lyf's Avatar
oh yeah!
Is the electro-hydraulic rack something that Mazda warranty's?
reason I am asking is because mine is crapping out on me. It started catching every time i would turn left and it has gotten worse, so I took it to a dealership that I got it from (not mazda dealer) and the part alone the guy said was $1500.00
All together the price was $3652.00 because I need new tires as well which were like 700.00
He said it would take a week for them to fix it because they have to drop the engine or something.
Does this sound like he is trying to rape me in costs or is there somewhere I can get this part online?
Thanks for your help
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
