Preventive aftermarket parts?
Old Apr 6, 2010 | 01:55 PM
DOPE619's Avatar
booty
i dont think this is in the wrong place, but i couldnt find a thread summary for preventive aftermarket parts, can anyone list some of the parts, that would be a good idea to replace, more for maintenance, rather than gains?
BHR RADIATOR:
http://blackhaloracing.com/products-...bhr-radiator6/
RICHARD SOHN OMP ADAPTER:
http://www.rotaryaviation.com/oil_in...p_adaptors.htm
TUNE UP KIT:
http://atkinsrotary.com/store/catalo...t-p-17026.html
COBB ACCESSPORT:
http://www.cobbtuning.com/products/?id=3812
REINFORCED CLUTCH PEDAL BRACKET ASSEMBLY:
http://raceroots.com/index.php/produ...-assembly.html
IDEMITSU PREMIX:
http://www.rotorsportsracing.com/per...g/idemitsu.htm
MAZMART WATER PUMP:
http://www.mazmart.com/ItemDetail.aspx?id=265
Old Apr 6, 2010 | 02:02 PM
Search for, premix, Richard Sohn Adapter, BHR coils, BHR or Mazmart Radiator, Mazmart water pump, and Cobb access port.
Old Apr 6, 2010 | 02:57 PM
Koyo is crap, that is what I have and now my car runs hotter than it did with the stock one. I am in process of dealing with it at the moment even though it is only a month old. It's not an issue now but i bet it will be when I am on the track in 100F weather.
I was cheap, don't be. Just get the Mazmart or BHR.
Old Apr 6, 2010 | 03:38 PM
bse50's Avatar
#50
Radiator, water pump (Mazmart's), BHR coil upgrade and the right lubricants.
Premix
High flow cat.
Oil pressure mod, maybe. I like it but there's no hard data to back it up.
Change the radiator ONLY if you have to. Excessive cooling is dangerous.
Old Apr 6, 2010 | 03:52 PM
Yes, depending on where you live there could be over cooling issues.
Old Apr 6, 2010 | 05:16 PM
taylorkrobson's Avatar
I would also recommend the reinforced clutch pedal bracket and assembly.
Old Apr 6, 2010 | 06:14 PM
c0ldf1ame's Avatar
regarding the koyo, one of my friends said he noticed a pretty big gap underneath the koyo between his stock under tray, he has since filled the gap with some foam and noted that his temps are much better than before. I dont know from first hand experience, but this is what i've heard.
Next on my list of things to get is the water pump and thermostat from mazmart
Old Apr 6, 2010 | 06:19 PM
c0ldf1ame: yup, most of these radiators do not have the foam around the edge like the OEM and that allows air to escape.
Whenever you install an aftermarket radiator, make sure to reuse the foam off the OEM or go buy some extra.
You guys would be amazed at how much of a difference that foam can make.
Old Apr 6, 2010 | 08:19 PM
boarderjosh10's Avatar
Resident Cool Guy
Proper catch can?
Old Apr 6, 2010 | 08:28 PM
nah, I dont' consider catch cans to be all that important.
I've never had one, and never needed it.
Sifu
Aug 30, 2015 10:51 PM
Kahl
Aug 20, 2015 11:49 PM
AllSeeingChris
Aug 16, 2015 12:35 PM
MolecularConcept
Aug 5, 2015 04:43 PM
madrotor
Jul 26, 2015 12:06 PM
