How do I know if I need new shocks?
Old Apr 4, 2010 | 03:13 PM
boarderjosh10's Avatar
Resident Cool Guy
My ride seems to be a lot more rough than it used to be. I was thinking that I might have worn out shocks or springs. I have an 04 Sport AT, and I don't really know about all of the components that go into the ride comfort. I want to lower the car pretty soon on some Tein S tech springs, but I'm not really sure if I should if my shocks are worn out. I searched and read the thread about coilovers/springs and other basic suspension info and I gathered that my car has a shock/spring combo. How do I know if my springs are bad or if my shock is bad?
thanks!
Old Apr 4, 2010 | 03:18 PM
How many Miles on your stock ones...if it's more than 60K..you might as well put some Koni's or something in if you are doing a spring install....
By 60K they are getting weak
Old Apr 4, 2010 | 03:24 PM
Easy_E1's Avatar
Does your car behave like this?
[embed]<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/C8Kw5jiwhv4&hl=en_US&fs=1&color1=0x5d1719&color2=0 xcd311b"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/C8Kw5jiwhv4&hl=en_US&fs=1&color1=0x5d1719&color2=0 xcd311b" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>[/embed]
Old Apr 4, 2010 | 03:42 PM
Resident Cool Guy
My car just hit 70,000 last night so it is probably time to replace the shocks too. My car doesn't drive like that yet Easy. Which Koni shocks do you recommend?
Old Apr 4, 2010 | 03:59 PM
Too funny....hope they aren't that bad
Koni yellows are a good low cost shock.....They have been on sale a few places lately less than $700 for all 4
Old Apr 4, 2010 | 05:50 PM
ZumnRx8's Avatar
RX8 & RX7 owner
If you are past 50k miles..... its time. Im at 75k and still havent changed them.
Old Apr 4, 2010 | 05:55 PM
Spin9k's Avatar
Momentum Keeps Me Going
Another point to consider is the condition/age of your tires. If they are worn, they will ride rough. New quality tires on a car can do wonders for the ride quality. I've seen that time and again....take a crappy riding used/old car. Put some new rubber on it and wow...you'll feel like you're riding on air.
If however you are bouncing and crashing over bumps, suspension may be the culprit. And the condition of the roads you frequent can cause early wear on shocks. Smooth road/highway driving can prolonge their life.
Old Apr 4, 2010 | 10:38 PM
Resident Cool Guy
I have brand new tires, maybe 5k miles on them if that. The reason I think that its my shocks is that bumps seem much more intense everytime I go over them. Also sometimes I hear a weird "bouncing" sound after a bump as if my spring continues to taper off its vibration. A friend that was in my car said he heard the sound and thought it could be an endlink, sway bar or my shocks; kind of a wide variety of parts all relating to my suspension. Now I guess it's time to break out the credit card...
Old Apr 10, 2010 | 02:35 AM
Turblown's Avatar
Boostin'
If you decide to go the used route, we specialize in Koni damper service.
http://turblown.net/store/index.php?productID=72
Old Jun 28, 2020 | 11:17 PM
Respectedwealth's Avatar
Shocks
I have a 06 AT at 98000 miles and need to replace the rear shocks. What would you recommend for just daily driving.
Old Jun 28, 2020 | 11:21 PM
Replace all 4 at the same time....
You could go with Bilstein or Koni or other OEM equivalent.... if you plan on staying stock you have lots of choices
You could get some decent entry level coilovers for not that much more and get a nicer look
Nisaja
15
Nov 21, 2015 10:30 PM
duworm
Oct 1, 2015 04:57 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Paul_Y
Sep 21, 2015 02:23 PM
FoxRacer600RR
Aug 31, 2015 06:32 AM
