Slip light is on since I re-connect the battary
Old Mar 31, 2010 | 12:13 PM
reverse01134's Avatar
Slip light keeps on since I re-connect the battary
I disconnected and connected the battary again to remove the radio. everything works fine but since I re-connected the battary, slip light keeps on. DSC off light was flashing too but it disappeared after driving a minute. but the slip light keeps on. What is wrong with it? anyone has this experience?
Old Mar 31, 2010 | 12:36 PM
Huey52's Avatar
Registered Zoom Zoomer
Slip light? There is a common TCS/DCS light.
"This indicator light stays on for a few
seconds when the ignition switch is turned
to the ON position. If the TCS or DSC is
operating, the indicator light flashes.
If the light stays on, the TCS or DSC may
have a malfunction and they may not
operate correctly. Take your vehicle to an
Authorized Mazda Dealer.
NOTE
l In addition to the indicator light
flashing, a slight lugging sound will
come from the engine. This indicates
that the TCS is operating properly.
l On slippery surfaces, such as fresh
snow, it will be impossible to
achieve high rpm when the TCS is on."
"If the battery is disconnected, the DSC
will be inoperable. In this case, the DSC
OFF indicator light flashes and the
TCS/DSC indicator light illuminates.
To make the DSC operable, do the
following procedure.
1. Turn the ignition switch to the ON
position.
2. Turn the steering clockwise fully,
then turn it counterclockwise fully.
3. Make sure the DSC OFF indicator
goes off.
4. Turn the ignition switch to the OFF
position, then turn it to the ON
position again.
5. Make sure the TCS/DSC indicator
light goes off.
If the TCS/DSC indicator light and the
DSC OFF indicator light remain
illuminated even after turning the
ignition switch to the ON position,
consult an Authorized Mazda Dealer."
(an Owner's Manual is a wonderful thing)
Old Mar 31, 2010 | 01:11 PM
dillsrotary's Avatar
jersey fresh
^ding ding!
Old Mar 31, 2010 | 02:32 PM
Rota II's Avatar
Its better the 2nd time
WOW... I was gonna answer his question becasue i knew the anwser, but HOLY COW Huey, nice answer! Although, you didnt give him the page number. LOL
Old Apr 1, 2010 | 07:32 AM
Huey52's Avatar
^ LOL, but thanks. Just a simple cut & paste from my .pdf version of the manual, which is readily available to anyone, by model year, on Mazda's site (just sign up as an owner).
Old Apr 1, 2010 | 12:05 PM
Pico's Avatar
It's Complicated
Huey to the rescue.
Owners manual is your friend
Old Apr 1, 2010 | 01:14 PM
Grungepup's Avatar
Oilfield trash
damn i knew this one too....
Old Apr 1, 2010 | 05:39 PM
MazdaManiac's Avatar
Synopsis:
Turn your steering wheel both ways to the lock and cycle the ignition.
cliffkemp
Dec 24, 2024 10:48 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
