Hot Start Turbo
Old Mar 29, 2010 | 05:26 AM
Ludkut's Avatar
Hot Start Turbo
Hey i recently installed a Greddy turbo on my RX8, and im having trouble, i cant start it when its hot. Im using turbo sparks from RX-7 9's all arround and still no effect , could it be from the lambda probe? Or is it from the Air-fuel ratio or timing, does it require some tuning, i need help/advice.
P.S. I talked to Jeff from Mazdamaniac, but all i got was 1 reply asking what year my car is
P.P.S. The car is 2004 5 speed MT 192PS RX7
Old Mar 29, 2010 | 06:57 AM
bse50's Avatar
#50
Low compression?
Old Mar 29, 2010 | 07:35 AM
RX8YA's Avatar
WAH WAH WAH
He may have been asking for the year because starters were upgraded. I think 04-05 have starters dont crank as well.
Old Mar 29, 2010 | 10:13 AM
Ludkut's Avatar
I'm not sure about the compression, but i asume if its low its irreversible and unfixable?
Old Mar 29, 2010 | 10:43 AM
RX8YA's Avatar
WAH WAH WAH
^ Its fixable with a rebuild or a new motor however i wouldn't jump to conclusions just by those symptoms that seems premature.
Old Mar 29, 2010 | 11:57 AM
05rx8mazda's Avatar
B.I.G
sure you didnt install something incorrectly?
Old Mar 29, 2010 | 12:56 PM
halimsteven's Avatar
it's hard to start when it's hot? but it starts right up when it's cold?
may be your compression? fuel pump? coils? sparkplugs?
check all of those first..
steven
Old Mar 29, 2010 | 01:58 PM
Luckycat's Avatar
What engine management the car is run on? It could be the Cranking / Water temp MAP is out of wack. My car is running on Winter MAP right now (Microtech LT-10) and it starts fine below 60F. When temp is warmer than 60F I noticed that it difficult to start. Winter MAP injects more fuel than summer MAP and causes flood so car won't start. Need to reduce fuel.
Old Mar 29, 2010 | 02:27 PM
Ludkut's Avatar
I reverted the settings to the original ECU stock ones, and it starts even if i dont rev it before i turn it off, i guess i'll go from there i suppose, new injectors coming next week :> so i can make it run properly on higher rpms.
Old Mar 29, 2010 | 02:31 PM
Brettus's Avatar
Boosted Kiwi
ummm - you have a Greddy turbo right ? No need for larger injectors ....
What engine management are you using ?
Old Mar 29, 2010 | 05:40 PM
Ludkut's Avatar
E-manage ultimate, but do notice that my RX-8 is 4 ports 4 injectors, and i having my injectors working on a higher than 90% is bad, also on 6500 rpms they work on 100% and the AFR gets to 13.Also i get a spike on 4k rpms when i put the pedal to the floor.
Edit: Can you recommend anything better then the E-manage ultimate that is better? any tips would be apriciated.
Old Mar 29, 2010 | 05:51 PM
Brettus's Avatar
Boosted Kiwi
OK - I didn't realise it was a 4 port .
Cobb AP is lightyears ahead of the E-manage .
Where are you ?
Old Mar 30, 2010 | 12:42 AM
Ludkut's Avatar
I'm in bulgaria, but let me know if you want to contact me trough Private Message, so we can figure something out if that is alright with you?
Old Mar 30, 2010 | 12:59 AM
Brettus's Avatar
Boosted Kiwi
You can go to mazdamaniac.com directly and buy it off him - assuming the AP can service a euro 4 port .
Failing that get back to me and i'll tell you about what I'm using .
Old Mar 30, 2010 | 02:41 AM
bse50's Avatar
#50
Brettus is right, check with MM if your ecu is supported and get the accessPORT
Old Mar 30, 2010 | 03:02 AM
Ludkut's Avatar
I wrote a letter to MM but no answer so far, waited almost a week and a half, then i wrote another letter, because i thought that he didnt get it, i don't know how to get in touch with him :|.
P.S. Can someone link me or show me how the shims look like for trailing BUR 9's?
SUKIEE
Oct 9, 2017 09:41 PM
RayBarron
Oct 19, 2015 08:08 PM
PotatoCannon
Sep 6, 2015 11:48 AM
robd1337
Jul 31, 2015 09:35 PM
dbarber
Jul 25, 2015 01:34 PM
