Strange issue...
Old Mar 28, 2010 | 09:38 AM
I8U's Avatar
I8U
Strange issue...
Well I just had my engine replaced and now I had a CEL for secondary intake runner and SSV stuck open. Problem is it isn't stuck open, I can physically move them by hand. Sounds like a sensor issue, what do you think?
Old Mar 30, 2010 | 12:01 PM
zoomalot's Avatar
Who did the engine replacement? Can you take it back to have the problem analyzed?
Old Mar 30, 2010 | 06:39 PM
Likely the switch...or the actuator....or the vac lines from the solenoid...or possibly the solenoid or wiring
Check the actuator with a vac pump.....it should open/close with vac.
Old Mar 30, 2010 | 06:42 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Paging Jon316G.......party of one!
I'll qoute him here as one example:
"First thing I would check is for pinholes in the actuator... its happen a few times before.
If you have a vacuum pump (like from a brake bleeding kit), disconnect the airline to the actuator and hook the vacuum pump to it.
Give it vacuum (about 10in.Hg) and see if it holds the vacuum.
If you notice the vacuum going down, then you know the actuator has a pinhole".
It could also be the switch as said above in a post. Do a search on Jon's "SSV teaser video" thread there is tons of info in there.
Old Mar 30, 2010 | 08:27 PM
I8U's Avatar
I8U
The actuator is fine. Had a problem with it chattering a few months ago...had the engine replaced for a 3rd time under warranty. Dealership says it's not from the install and they will look at it but ofcourse want to charge me for it. They say the problem is probably pre existing and it's my problem not theirs, granted they covered all extra expenses with the engine swap of whatever Mazda didn't cover so, I really am in no position to ask them for more free stuff. I'll check the solenoid though.
Old Mar 30, 2010 | 08:51 PM
Jon316G's Avatar
Grasshopper
If the actuator is fine, I would check the solenoid and impact switch:
Here is a DIY I made for testing the solenoid:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-test-solenoid-190364/
And this is a post for testing the impact switch:
https://www.rx8club.com/showpost.php...7&postcount=41
You might also want to clean the electrical contacts to the solenoid.
You also mentioned it chattered a few months ago, does it still occur or do you just have a CEL?
Old Mar 30, 2010 | 08:52 PM
Grungepup's Avatar
Oilfield trash
I would call bs on that one..... if the codes werent there before the engine swap and now they are, i would say that they are responsible
Old Mar 30, 2010 | 09:13 PM
I8U's Avatar
I8U
I called BS...they say the only thing they were liable for was the engine itself since they installed the old parts from the previous engine. I'm gonna try and reason with them tomorrow...
Old Mar 30, 2010 | 09:15 PM
I8U's Avatar
I8U
https://www.rx8club.com/showthread.php?t=190364
The chatter is gone, just getting a CEL...I can move the actuators by hand so I know they are not stuck open.
Shankapotamus3
Mar 14, 2021 03:53 PM
Steve Dallas
RX-8 Racing
10
Oct 7, 2015 10:30 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
yankeepicker
Sep 11, 2015 05:42 PM
rxwilly8
Sep 2, 2015 02:42 PM
