Metra Kit - Windsheild Defroster/Mode issue
Old Mar 26, 2010 | 02:35 AM
Twiztog43's Avatar
Exclamation Metra Kit - Windsheild Defroster/Mode issue
i was reinstalling my metra kit [took it off previously] and every thing worked out fine. but one thing i noticed, is that there are three buttons that are unresponsive between the temperature and fan dials. one thing i noticed that doesnt work is my windshield defroster. but on the other hand my rear windshield defroster works fine. also the mode button doesnt work either. also the button that tells you where you want the air to go doesnt work either. what do you guys think it could be?
Old Mar 26, 2010 | 06:58 AM
RX8Geek's Avatar
You probably have a broken wire or contact between the kit and the switch module. If you are using extension harnesses, that would be the most likely spot. The harness on the "fan switch" side of the switch module would be the problem.
Old Mar 26, 2010 | 10:11 AM
Twiztog43's Avatar
alright thanks, ill check it out later today,.
and no, im not using the extension harnesses. i dont think my kit came with them. but i did have to tug on the wires a bit to get them next to the glove box.
Old Mar 26, 2010 | 10:19 AM
Twiztog43's Avatar
ok, this is weird, but i just checked it this morning when i started the car and all the buttons seem to magically work now
Old Mar 26, 2010 | 11:18 AM
Twiztog43's Avatar
ok, now after a quick drive, now the buttons dont seem to work anymore.
Old Mar 26, 2010 | 01:48 PM
RX8Geek's Avatar
The intermittent connection blues.
Old Mar 26, 2010 | 06:34 PM
Twiztog43's Avatar
well bad news, after checking the connections, my display went out. so now i went back to stock. i think its an issue with the axxces box
Warrior777
Jun 24, 2019 04:47 PM
RicerX1
Jan 11, 2016 05:59 PM
MolecularConcept
Aug 5, 2015 04:43 PM
04MazdaMan
Jul 15, 2015 08:23 PM
