hooking up rx8 engine harness to rx7 manual transmission
Old Mar 23, 2010 | 06:34 AM
stickmantijuana's Avatar
Unregistered User
how do i hook up rx8 engine harness to rx7 manual transmission?
thanks!
Old Mar 23, 2010 | 11:59 AM
secret8gent's Avatar
the enemy in the mirror
iirc rx8 6spd box has two connections, reverse and neutral. Does the rx7 trans have anything those? basically they are either shorted or open. So in a pinch you can probably ignore the neutral part of the harness (since you're replacing the EMS anyway) and wire the reverse directly to the taillight circuit.
anyway, i'm sure someone will chime in with all the deets (details)
good luck man!~
Old Mar 26, 2010 | 09:52 AM
that's major modification surgery, not a tech issue
be sure to post a DIY, lol ....
ASH8
Oct 30, 2021 12:50 PM
BigMikeATL
May 26, 2016 12:31 AM
CRAZ8
Jul 22, 2015 10:02 AM
