Cars with headlight washers + Mazdaspeed bumper
Old Mar 22, 2010 | 08:05 PM
BlackStealth's Avatar
So since only the Canadian cars get headlight washers (I could be wrong with my assumption...), I'm wondering what the best way to go about installing the mazdaspeed front bumper. There are really only two ways to go about it doing it:
a) Remove headlight washer motors, put on new bumper
b) Somewhow manage to (carefully) cut out the required holes in the mazdaspeed bumper
Obviously option b) is probably not a good idea unless you want to risk completely ruining your kit... but are there bumpers that have these pre cut that I'm not aware of? Any tips?
Old Mar 22, 2010 | 08:10 PM
Jon316G's Avatar
Grasshopper
Another option:
c) remove 20A fuse for the headlight cleaner and not worry about removing the motors.
Old Mar 22, 2010 | 10:58 PM
It just seems like such a waste though... are there no body kits available with this in mind?
I'm assuming trying to cut an appropriate rectangle through either urethane, plastic, or fiberglass is hopeless?
Old Mar 22, 2010 | 11:00 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
Cut it. Headlight washers shouldn't be that hard to rig.
Old Mar 22, 2010 | 11:01 PM
Jon316G's Avatar
Grasshopper
With a Dremel and a steady hand... maybe.
But do you really want to risk that?
I'm not an expert when it comes to various body kits so maybe someone else will chime in with a solution.
Old Mar 22, 2010 | 11:08 PM
kersh4w's Avatar
Hit & Run Magnet
body shop.
Old Mar 25, 2010 | 11:54 AM
yiksing's Avatar
the giant tastetickles
I just removed my original bumper and plug the washer hose with a screw.
Old Mar 27, 2010 | 07:16 PM
StuttgartRX8's Avatar
Nurburgring Camera Whore
I saw a 8 parked with the Mazdaspeed bumper a few weeks ago here in germany. It looked like he just cut it and still used the factory washers. I would of snapped a picture but I didn't have my camera on me.
Old Mar 29, 2010 | 07:31 AM
unleashedd's Avatar
I smashed my bumper a few months ago, and the weather just allowed me to start fixing it. Since i lost the left headlamp washer and left foglight in the shenanigans, i removed them both - well, as removed as they can be. If you decide to keep the washers, and the new bumper is urethane, id say dremmel it. I want mine gone, so i took it all out up to the pump. Since im using a stock bumper, with the washer cutouts, im just gonna duct/electric tape over them. And you guys just reminded me to go pop the fuse too. Thanks
Anyone have any clever idea what to do with the washer hose/assembly? I saw someone rigged theirs to the back and would squirt tailgaters
Old Mar 29, 2010 | 07:45 AM
rodjonathan's Avatar
silent assasin
just use a dremel youll be fine
Old Jul 4, 2013 | 09:15 PM
Mazda_RX804's Avatar
Hate Scrape 8
when you pull the fuse to disable washers, is it only the light washers that gets stop by that fuse? anything else gets effected? Do any dash lights come on?
Old Jul 4, 2013 | 09:23 PM
RX8Soldier's Avatar
Time for boost...
Yes, only the headlight washers are disabled. And no dash lights.
I unplugged the hose to the washer tank right behind the passenger wheel well liners and removed the fuse when I installed my MS bumper without any issue
Old Jul 6, 2013 | 11:51 AM
Hate Scrape 8
anyway in showing me which fuse this is? I misplaced my owners manual. Thanks RX8soldier for the tip
BigMikeATL
May 26, 2016 12:31 AM
MsKingRotary
Jan 28, 2016 12:12 PM
D13
Aug 22, 2015 11:42 PM
ktec
Jul 29, 2015 01:17 PM
AussieGray
Jul 16, 2015 03:58 AM
