Oil return for turbo systems....
Old Mar 19, 2010 | 12:50 PM
m4f1050's Avatar
Got these from Murray Speed & Custom shop.
1/4" NPT thread to #8 or #10 will do the trick, I added 90 deg elbow and a small 3" extension (using hose for modified oil pan which is closer to the front.)
Old Mar 19, 2010 | 12:52 PM
That's an expensive drain.....
Why all the fittings?
Old Mar 19, 2010 | 12:54 PM
laythor's Avatar
I zoom therefore I am.
that's alot of fittings. reminds me of a tinkertoy
Old Mar 19, 2010 | 05:07 PM
m4f1050's Avatar
The only 3 necessary are the 1/4 NPT (oil pan thread) to #8, a 90 deg #8 then from #8 to #10 to hose. That way you don't have to remove the original oil pan...
I had to extend it a few inches because I had cut the original hose not thinking I was going to do this, I had a modified oil pan with an inlet in the front area... You don't need the black ones, that's just 2" extension to make hose longer.
Old Mar 19, 2010 | 06:33 PM
laythor's Avatar
it's the prettiest, and most expensive, hose extender i've seen
i like to see things like this on DIY'ers cars, let's you know that the owner was doing the wrenching.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
Slack
Sep 5, 2015 06:42 PM
Cookingislife1226
Sep 5, 2015 03:38 PM
