What Are The Best Grounding spots in the engine bay?
Old Mar 18, 2010 | 09:28 PM
EdwardLenczowski's Avatar
NY What Are The Best Grounding spots in the engine bay?
I bought a buddyclub grounding kit and im wondering what the 3 best grounding points in the engine bay are. I was Thinking the two left grounds on the firewall near the washer fluid and maybe one ground to the alternator. Only got three wires so i wanna make them count!
Old Mar 19, 2010 | 06:36 PM
JessiahC's Avatar
Nitrous Threadjacker
The best grounding locations are found here.
Old Mar 19, 2010 | 06:52 PM
expo1's Avatar
He's as bad as Can
There are many factory grounding points throughout the bay, you could use some of those. Another option is to look up an aftermarket grounding kit and see if they have the install instructions online, you could use those points. HERE is an example of one I found.
Old Mar 19, 2010 | 07:09 PM
JessiahC's Avatar
Edward,
A quick search of "Engine Grounding Points" pulled up:
My grounding kit results:
https://www.rx8club.com/series-i-tech-garage-22/my-grounding-kit-results-84924/
DIY: Lineage Grounding Wire Install
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-lineage-grounding-wire-install-34997/
grounding kit + rear strut bar installed today
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/grounding-kit-rear-strut-bar-installed-today-132744/
Grounding Wire Kits Info/Questions
https://www.rx8club.com/series-i-tech-garage-22/grounding-wire-kits-info-questions-16989/
If these threads are not sufficient then I would suggest you not go through with the modification, as it could lead to potential electrical system damage and/or personal injury.
Old Mar 21, 2010 | 09:07 PM
perks11's Avatar
HEADTURNER
just the type of thread i was looking for!!
Old Jan 25, 2025 | 02:24 PM
TopGunM2k's Avatar
*RISE FROM YOUR GRAVE*
Resurrecting this thread as I just did the Big 3 upgrade (big gauge wire from chassis ground to negative battery post, engine ground to chassis ground, and positive post to alternator) and there is a difference on startup and idle (nice, quick, and smooth). I wanted to add if you plan to do this many ground points; you might as well install a heavy duty gauge wire (4 gauge) to go from the positive battery post to the alternator. All my vehicles with sound system have The Big 3 upgrade and this always fixes the dimming lights when the subwoofer comes on. I also add the capacitor which can be overkill but think it's worth the small investment to complete the sound system.
Old Jan 27, 2025 | 03:06 AM
RxRuben's Avatar
do you know or have any sites where I can find these "grounding kits" and even maybe a installation demonstration. i have found a site from a previous discussion on grounding kits, but i still have a small hint of what to do
Old Jan 27, 2025 | 06:54 PM
TopGunM2k's Avatar
If you search enough; there's plenty of threads in this website where they demonstrate the installation with pictures. You don't really have to buy a kit which all seem to be over priced IMO. Most local stereo stores will have what you need and can provide the 4 gauge wire that is recommended to increase the ground points. Google "Big 3 upgrade" and you will also get more info on kits and instructions. This is more for cars with aftermarket stereos but benefits the Rx8 from my personal experience with or without the upgraded stereo system.
BigMikeATL
May 26, 2016 12:31 AM
uZu
Dec 30, 2015 12:35 PM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
iSki123
Jul 27, 2015 12:41 PM
