Sorry this might be a dumb question.
Old Mar 17, 2010 | 07:09 AM
buteman's Avatar
How can I tell if my 8 has the TPMS ??
Old Mar 17, 2010 | 07:23 AM
RIWWP's Avatar
Quick answer: I believe TPMS was standard on all 8s, regardless of year and trim. If you still have the OEM wheels, you should still have the TPMS sensors on them.
Longer answer: If you go out to your car, let a bunch of air out of a tire, drive around the block (carefully, obviously, and make sure you have a pumping method on hand or you drive to a gas station that has one), you should get a 3-beep tone with a warning light on your dash.
Old Mar 17, 2010 | 07:28 AM
SheffieldSteel's Avatar
Intended acceleration
In order of convenience...
The TPMS (_) light should light up briefly whenever you fire up the engine.
Let the air out of one of the tyres and the light will light up consistently when the engine's running.
Look inside the tyres for the sensors.
Old Mar 17, 2010 | 08:07 AM
CTrx8's Avatar
space for rent
actually, without even having to deflate the tires, if the light isn't constantly flashing when you're driving, they have TPMS. it would be lit all the time if someone had swapped them out (assuming the light is working and comes on when you start the car).
Old Mar 17, 2010 | 08:53 AM
Silverisk8's Avatar
even the sensors go bad... only two ways to know, one is the way CTRX8 said the other is go to a garage and pop the tires off, most ocasion the sensors go bad... just hope thye didn't
good luck
Old Mar 17, 2010 | 05:09 PM
rodjonathan's Avatar
silent assasin
i think the tpms was standard on the 8s minus the ones with the 16s
Old Mar 17, 2010 | 05:11 PM
WTBRotary!'s Avatar
Drummond Built
Wrong, before I sold my base model auto 8 it had TPMS...
lol now i have a 05' WB 6MT GT!!! woot /end threadjack
Old Mar 17, 2010 | 06:27 PM
spigot52's Avatar
No TPMS on Canadian Models. But we got headlight washers.
Old Mar 17, 2010 | 07:16 PM
lilring's Avatar
Finally a MT
even the 16 inch wheels got them. All USA rx8 came standard with TPMS
Old Mar 17, 2010 | 07:19 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Bingo!
Spigot is right!
Canadian models = no TPMS.......but head lightwashers!
You guy should read where he posted from. Unless he bought a US model, he's SOL.
Old Mar 17, 2010 | 07:26 PM
shazy's Avatar
Mine doesn't have TPMS ...
Canada ftw?
Old Mar 18, 2010 | 04:48 AM
JessiahC's Avatar
Nitrous Threadjacker
Originally Posted by Mazurfer
Bingo!
Spigot is right!
I would much rather throw out that annoying TPMS light for some headlight washers, aye.
Old Mar 18, 2010 | 09:50 AM
jasonrxeight's Avatar
it can be annoying when your car is clean but you want to wash your winsheild tho.
unless they are controlled seperately.
Mazurfer's Avatar
I don't know.........think I like the TPMS better as it alerts you when you drop under 26lbs of air. Most people don't check their tire pressure as often as they should, so I think it's a good thing...............especially if you are gonna push the car in corners etc. In this case you should be checking it more often of course, but at least you will know if you are starting to reach critical mass before it's too late!
Headlight washers............meh.........I never let my car get that dirty.
Old Mar 18, 2010 | 09:54 AM
laythor's Avatar
I zoom therefore I am.
dirty headlights.... there's a topless woman joke in there somewhere.
Old Mar 18, 2010 | 09:58 AM
Mazurfer's Avatar
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
zoom44
General Automotive
Nov 16, 2015 11:38 PM
neoksk
Sep 21, 2015 12:31 PM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
