Battery Drain
Old Mar 16, 2010 | 11:46 PM
WVBoosted8's Avatar
Battery Drain
Hey guys I hadn't driven my car in a month and went to start the car and of course the battery was completely gone. I took the battery (optima yellow top) to advanced and they swapped it out for free since it was still in warranty. Now I am afraid the same thing will happen to the new one if there is some sort of drain that I don't know about.
I tested the draw with a 10 amp multimeter and it read .09. I have read that anything over .05 is probably something pulling power when it shouldn't be. I have checked all of the fuses and it never goes lower. Do you guys think .09 is reasonable or is there a problem?
Old Mar 17, 2010 | 12:22 PM
EDZRIDE's Avatar
2005 White GT
Do a search on "Dark Current".
Old Mar 17, 2010 | 12:52 PM
Silverisk8's Avatar
dont activate your factory alarm if you aint going to use the car in a while, eventually it will drain your battery in less than 2 weeks if you don't use it for that long, you said you havent used the car in a month so there's your problem, just lock the doors manually ( DON'T ACTIVATE YOUR ALARM )
Good Luck !!!
Old Mar 17, 2010 | 12:56 PM
xun4gvn4everx's Avatar
True love is blue x2
An alternate solution which is usually used for upgraded sound systems, is to get a capacitor. Though it would have to be wired differently than when used on an amp
Old Mar 17, 2010 | 07:09 PM
WVBoosted8's Avatar
The factory alarm wasn't active and the system shouldn't draw anything since the remote is on a switched fuse. Does anyone know if .09 is too high?
Old Mar 17, 2010 | 07:11 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Well..............I like you have read that 50mA is about what it should be drawing, so there is a llittle something going on. Have you looked through the passthrough and made sure your trunk light is off?
Stupid question, but could the cobb being drawing that much when off?
What else you got in terms of electrical mods?
If nothing else, you can start pulling bulbs while on the meter and see if you have a bulb possibly creating a path but not shorted completely??????
Old Mar 18, 2010 | 01:40 AM
WVBoosted8's Avatar
Im going to look at some things on friday and see if by any chance it is the metra kit hooked up incorrectly or something. I don't leave the cobb ap plugged in while I am not driving the car either. Thanks for all your help
Old Mar 18, 2010 | 09:33 AM
Although the metra kit is an aesthetically pleasing mod, I find that a good number of people have had problems with it. Usually due to incorrect installation. I would def start there. Might even wanna try taking it out and reinstalling the OEM parts to see if the draw is any different.
Old Mar 18, 2010 | 10:25 AM
WVBoosted8's Avatar
Well the only problem with that is you have to completely disassemble the factory deck in order to install the metra kit lol.
Old Mar 18, 2010 | 10:59 AM
haha yea, I know it is a biotch. The other possibility is to pull the fuse for it, similar to what Mazurfer suggested, and check your draw
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
