What's your STX set-up? (2010 edition)
Old Mar 15, 2010 | 10:29 AM
chiketkd's Avatar
Row faster, I hear banjos
Saw this on miata.net and thought it would be a good idea for those who don't care to play their cards close to their chest.
Let's try to keep the same format, for easy reference. I'll start off...
Model: 2006 6MT RX-8 base (sport package)
Suspension:
  • Bilstein PSS9 coilovers (w/ 7K Swift front springs)
  • Hotchkis 27mm MX-5 FSB (3 way adjustable)
  • Eibach 16mm MX-5 RSB (2 way adjustable)
Brakes:
  • OEM pads and rotors
Engine/Exhuast:
  • RB intake
  • BHR ignition kit
  • RB mid-pipe (with Davesport cat and Vibrant 12" resonator added)
  • Corksport catback
Wheels:
  • 17x9 +45 Enkei RPF1's
  • 255/40/17 Hankook RS-3's (full tread)
Body:
  • OEM front lip and rear spoiler
Alignment:
  • Height F 13.5" / R 13.5"
  • Caster 7.0
  • Camber F -2.5 / R -2.0
  • Toe F 0 / R 0
Other:
  • Optima Red Top Battery
Old Mar 16, 2010 | 12:43 PM
iaus10's Avatar
0110100001101001
My "phase 1" of the stock to stx conversion.
Model: 2004 6MT RX-8 base
Suspension:
* Koni Sport d/a valved - Progress Tech springs
* Hotchkis 27mm MX-5 FSB
* Stock or no rear bar
Brakes:
* OEM pads and rotors
Engine/Exhuast:
* Cobb AP
Wheels:
* 17x9 +45 Enkei RPF1's
* 255/40/17 Hankook RS-3's (full tread)
Body:
Alignment:
* Will know more after getting it back on the alignment rack.
Other:
Lightweight battery
Corbeau Forza driver's seat.
Old Mar 16, 2010 | 08:56 PM
GeorgeH's Avatar
Model: 2004 6MT RX-8 Sport (Damn stability control button!)
Suspension:
  • FatCat revalved, double adjustable Bilsteins w/Swift springs, custom bump stops, etc.
  • Whiteline front anti-sway bar, 3-way adjustable
  • No rear anti-sway bar
Brakes:
  • OEM rotors, Racing Brake ET800 pads
  • Racing Brake SS lines
Engine/Exhuast:
  • Custom mid-pipe with Davesport cat
  • Corksport catback
  • Underdrive Pulley
  • AccessPort w/custom Surgeline tune, 210 rwhp
Wheels:
  • 18x9 +35 SSR Type Cs
  • 265/35/18 Bridgestone RE11s
Body:
  • Contingency Stickers
Alignment:
  • TBD
Other:
  • Odyssey PC680 Battery
  • Sparco seats
  • Evo instructor as co-driver
  • MaxQData data/video aquisition
Old Mar 16, 2010 | 11:37 PM
S0l08's Avatar
Model:
*2009 Sport 6mt
Suspension:
*Bilstein PSS9 coilovers
*Hotchkis 27mm MX-5 FSB (3 way adjustable)
*Eibach 16mm MX-5 RSB (2 way adjustable)/Sock redrilled bar
Brakes:
*OEM pads and rotors
Engine/Exhuast:
*S0lO8-Speed custom Getto Exhaust
Wheels:
*17x9 +45 Enkei RPF1's
*255/40/17 Hankook RS-3's (full tread)
Alignment:
*Camber F -2.7 / R -2.2
*Front toe out, rear toe in-verry little don't remember how much
Other:
*Walmart Motorcycle Battery-8lbs.
*NRG Carbon Fiber Seats-Custom Brackets W/weight added
Old Mar 17, 2010 | 12:10 AM
maskedferret's Avatar
Oooh, shiny!
I was originally going to stay in stock class, but my stock intake is coming apart so I decided to get the AEM CAI. I may as well go all in now, eh? When all is sorted out, here is what I'll have:
Model:
  • 2006 GT 6MT
Suspension (stock, but these are planned):
  • Koni shocks planned to be put on the car (for stock class); may go a different route.
  • swaybars ... something
Brakes:
  • Stock(ish) rotors
  • Cobalt Friction Sport GT pads
Engine/exhaust:
  • AEM CAI
  • Cobb AP (planned)
  • BHR Ignition System (planned)
Wheels:
  • 18x8 +48 SSR Comp-H
  • 245/40/18 Potenza RE-01R
Body:
  • Appearance (aero) package
  • Front splash guards
Alignment:
  • Caster 7.0
  • Camber F -1.4 / R -1.8
  • Toe F 0 / R 1/16
Old Mar 17, 2010 | 07:51 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
I already had some mods on my car when I bought that put me outta stock class, but now that its not my only vehicle, I was able to prep it all winter.
Model:
  • 2004 GT 70k miles
Suspension:
  • Tein H-Techs with Tokico D-spec - still haven't found an adjustment I like. . .
  • swaybars : Progress Front and Rear with Lebren adjustable endlinks
Brakes:
  • Drilled and Slotted rotors (unknown brand )
  • Hawk HP+
  • THMotorsports: Fluid Transfer Products SS Brake lines.
Engine/exhaust:
  • Racing Beat intake w/o duct.
  • Mazmart colder thermostat
  • 5w30 Royal Purple engine - redline trans and dif
  • Racing beat Plug wires
  • Racing Beat gauges and pod
  • Dave's Sport 100cpi cat welded in RB test pipe, 2.5 inch though
  • Agency Power dual catback.
  • AFE Short Shifter
Wheels:
  • 17x8 Kosei K1TS - 15lbs
  • 255/40 Dunlop Star Specs (ballooned, but they'll fit)
Body:
  • Cone Damage
  • Aero Package
  • RB Oil cooler and Radiator screens?
Alignment:
  • Haven't touched alignment yet, gotta read up on it. Part of the reason why I'm sharing on this thread, so I can get pointed in the right direction.
Old Mar 17, 2010 | 12:40 PM
BRODA's Avatar
Not yet famous
Edited for 2012 season.
Model: 2004 6MT RX-8 Sport Package / Cloth / Non-sunroof
Suspension:
  • Ohlins DFV Coilovers - Custom valved at PSI
  • Swift Springs: 11 kg/mm (F) / 6 kg/mm (R)
  • Racing Beat Front Swaybar
  • Racing Beat Rear Swaybar (disconnected)
  • Racing Beat Upgraded Endlinks
  • JIC Shock Tower Brace (Front)
  • Delrin Front UCA Bushings
Brakes:
  • Racing Brake 13" Big Brake Kit (Front)
  • Racing Brake 2-piece Rotors (Rear)
  • Hawk HPS Pads (F&R)
Engine/Exhuast:
  • RB intake
  • BHR ignition kit
  • Custom midpipe
  • HJS Motorsport 100 cpi cat
  • Two Coast Fabrication racing mufflers
  • Modified Borla catback
  • Racing Beat PCM flash
Wheels:
  • 18x9 +55 SSR Type-C
  • 255/35/18 Hankook Ventus R-S3 (new)
  • 255/35/18 Toyo R1R (used)
Body:
  • Stock
Alignment:
  • Ride Height Approx. 13.25" F&R
  • Camber F -2.9 / R -2.4
  • Toe Front 1/8" total toe out
  • Toe Rear 0
Other:
  • VoltPhreaks VPH900 7.5lb Battery (relocated to trunk)
  • Delrin differential mounts
  • Polyurethane motor mounts
  • Race Technology DL1 data logger
  • GoPro Motorsports Hero HD video camera
Old Mar 17, 2010 | 09:50 PM
altiain's Avatar
Sparky!
Okay, I’ll play.
Model: 2004 RX-8 Sport Package
Suspension:
  • Endura-Tech rebound adjustable coilovers, 8 kg/mm front, 5 kg/mm rear springs
  • Progress Technology adjustable front sway bar
  • Racing Beat front endlinks
  • Rear sway bar varies per site (none, OEM RX-8, OEM MX-5)
Brakes:
  • OEM rotors
  • Carbotech pads XP10/XP8 f/r (my track pads, but I find they provide more initial bite at autox speeds than OEM)
Engine/Exhaust
  • ”Isley special” axle-back exhaust
Wheels
  • 17x9 +35mm RPF1s
  • 17x9 +35mm FN01RCs
  • 255/40-17 Dunlops (full tread) on the RPF1s
  • Undecided yet on the FN01RCs
Body
  • Front undertrays bolted together after countless cone hits
  • Front bumper cracked from cone strike
  • Front end sandblasted from 3000+ open track miles
  • Slight dent near trunk lid from propane tank
  • Factory “Bass Boat Green” paint (what’s left of it)
Alignment
  • More camber than chike, but less than Isley.
  • 8.0 degrees of caster
  • 1/8” toe-out front, 1/8” toe-in rear
Other
  • Sparco 3” camlock lap belt
  • Scangauge II OBDII monitor
  • MaxQGPS datalogger
  • drinking habit
  • STX 2nd & 3rd place at 2010 Fort Worth National Tour
Old Apr 29, 2010 | 11:51 AM
chiketkd's Avatar
Update: See my original post for the recent updates to my front spring rate and alignment. I'll stick with this set-up for the remainder of the 2010 season.
Old Apr 29, 2010 | 08:04 PM
dmitrik4's Avatar
please wait for the beep
chike- no header?
also, how'd you get -2.5* camber with 6.5* caster?
Old Apr 29, 2010 | 08:31 PM
chiketkd's Avatar
Originally Posted by dmitrik4
chike- no header?
Mike,
My car is lowered by ~1" compared to when I was on konis in B-stock. 6.5* caster w/ -2.5* camber is very doable. FWIW, I got -2.0* camber and 4.5* caster when my car was in stock class.
I wasn't sure I could pass sound with the RB header. With the Davesport cat and vibrant resonator I'm already somewhere around 90dB @ 50ft. The header would have made the car MUCH louder.
I'm pretty happy with the car as it currently sits. It's the perfect weekend car/occasional daily driver.
-Chike
Old Apr 30, 2010 | 10:52 AM
tiresmoker's Avatar
Trust me, you're wrong
Model: 2005 Shinka
Suspension:
  • Stance GR+ coilovers (10k spring up front and 8k spring in the rear, upped to stiffer)
  • Progress front 3 way sway bar
  • Progress Rear 2 way sway bar, or no rear sway bar (depends on course)
  • RB front endlinks
  • Lebren Rear endlinks
  • Mazdaspeed strut tower brace
Brakes:
  • OEM rotors
  • HP Plus pads front and rear
  • Russell SS brake lines
  • Russell SS clutch line
  • Superblue Dot 4 brake fluid
Engine/Trans/Exhaust:
  • Custom midpipe with Magnaflow HFC (V-band swappable for straight pipe) with 12" resonator
  • Borla cat back
  • AEM CAI (rerouted to be STX legal)
  • BHR coils and wires
  • AFE SS
  • Redline fluids in trans and diff
Wheels:
  • 17x8 +45mm Motegi Traklite
Body:
  • Broken front lip from cones
  • Drivers door scratched from hitting cones on a 40 degree day
  • Vinyl class/numbers on car, with assorted other SCCA vinyl
  • Hail damage on hood, trunk, and roof
Alignment:
  • Lots of camber
  • lots of caster
  • some toe out here and there.
Old Apr 30, 2010 | 12:06 PM
Oooh, shiny!
What about it in its regular form makes it not legal for STX?
Old Apr 30, 2010 | 12:12 PM
chiketkd's Avatar
The plastic "splash shield" has to be removed to run the AEM/Mazdaspeed intake. This shield must remain in place in STX.
Old Apr 30, 2010 | 12:22 PM
Oooh, shiny!
Err, I don't recall a "splash shield" that I removed... Got a picture?
Install instructions: http://www.aemintakes.com/instructio...1-485_inst.pdf
Additionally, how is this "modification" implemented?
On a tangent, I recall having to bend a metal extrusion to the left of the filter element to allow it to clear; what is that thing?
Old Apr 30, 2010 | 12:55 PM
tiresmoker's Avatar
Step Af in the instructions, page 10. Becuase Mazda named the plastic piece the "upper radiator shroud" or something like that, it has to stay in place and cannot be removed or cut/modified to allow the intake pipe to pass through it, because it is part of the cooling system and not the intake system.
Basically you have to route the filter/piping to the same location that the stock intake inlet is/was routed along.
For the most part local level autocrossing shouldn't be that big of a deal, but at National Tours, and Pro Solos you will want to make sure that the intake is rerouted so it's legal as someone will more than likely protest. Better to be 150% safe then sorry.
Old Apr 30, 2010 | 01:02 PM
chiketkd's Avatar
+1
Btw maskedferret, this post should give you more info (includes a diagram):
https://www.rx8club.com/showpost.php...&postcount=116
Old May 1, 2010 | 10:00 PM
MilesJ's Avatar
Now that I finally have some parts to brag about I'll post in this thread.
Model: 2007 6MT RX-8 Sport
Suspension:
* Bilstein PSS9 coilovers
* Hotchkis 27mm MX-5 FSB (3 way adjustable)
* Hotchkis 21mm MX-5 RSB (3 way adjustable) - may swap for a smaller bar if it's too tail happy.
Brakes:
Engine/Exhuast:
* Stock Intake (planning on 6" filter with podram and thermal isolation box)
* Stock Exhaust (planning on adding a 2.5" highflow cat with extra resonator in stock midpipe and reusing the b-stock exhaust rear section)
Wheels:
* 17x9 +42 WedsSport TC-005
* 245/40R17 Bridgestone RE-01R (3 years old, fronts are corded)
Body:
* OEM, front undertray has extra screws/hardware in it to hold it together after a stray semi truck tread had its way with it.
Alignment:
* Height F 13.5" / R 13.5"
* Caster: L 8.07 / R 8.12
* Camber: F -2.25 / R -1.6
* Toe F 0 / R 0
Other:
* OEM Cargo Net (the only option my car came with)
* Need Access Port + tune.
* Hail damage to roof, hood, fenders and trunk (adds aerodynamic drag to the top of the car to help with high speed stability... yeah... that's the ticket.)
Last edited by MilesJ; May 28, 2010 at 12:51 PM. Reason: Aligned!! See alignment specs!
Old May 28, 2010 | 12:55 PM
MilesJ's Avatar
Originally Posted by MilesJ
Alignment:
* Toe F 0 / R 0
Got the alignment done. I'm at a lower ride height than initially anticipated but I like the alignment specs. Thanks to Trent (Chris) Harvey with the help deciding what to go with.
Old Jul 20, 2010 | 01:27 PM
Rosko350z's Avatar
I Heart 2nd Gear Racing
If my car is setup as per the details below, how far off of STX pace would I be on say .... a typical 40 second course. I know this isn't scientific and a real answer is impossible, but just give it your best guess.
The winner of last year's National STX class is pretty much local. I'd like to know how far I would be off of him ... if my car were driven by somebody as good as him Of course, I won't be able to attain that time, but it's nice to have goals
Model: 2007 6MT RX-8 base (sport package)
Suspension:
* Koni yellow springs
* OEM Anti Roll bar
* Progress Technology Springs
Brakes:
Engine/Exhuast:
* Removal of stock muffler (is this legal?)
Wheels:
* 17x8 +35 5zigen FN01R-C
* 245/40/17 Dunlop Star Spec
Body:
* OEM front lip and rear spoiler
Alignment:
* Caster 6.5
* Camber F -2.0 / R -1.8
* Toe F 1/8" out / R 0
Is this alignment possible on a stock RX8? I had the alignment done about 2.5 years ago, and they could only get (IIRC) about -1.8 front and -1.6 rear.
Old Jul 21, 2010 | 12:19 PM
Rosko350z's Avatar
^^^^^ Anyone?
Old Jul 21, 2010 | 12:40 PM
GeorgeH's Avatar
It's impossible to say, since you don't tell us how your competitors car is configured.
But, assuming he has a decent set of coilovers, 9" rims with one of the top tires, some weight reduction measures, some power adders, and is decently setup, his car will be faster. I won't hazard a guess as to how much.
Having said that, if you are a substantially better driver, you should be able to catch him. If he is even a marginally better driver than you, again assuming a decent STX setup, you are toast.
Old Jul 21, 2010 | 12:59 PM
TopGear8's Avatar
mkuhnracing.com
If his time was a 41.4 then your time would be a 43.9
Old Jul 21, 2010 | 01:10 PM
GeorgeH's Avatar
I will say that you have a decent starting point for local events - enough to have fun on. Just go out, have a good time, and take rides with faster drivers, either in your car or in theirs, to learn about fast driving. Then upgrade the car when you can.
You'll find that most of us are hesitant to comment on "how much slower is my setup" mainly because it's impossible to know and driving technique is so important.
Getting the tread back on topic, I could never get -2.0 camber out of the front of my car with stock springs, but with a lower ride height it's more likely. Not sure how low the PT springs go. I get -2.5 with my car, with a fairly low front ride height.
Deleting the cat-back is legal, I do believe, but it will be very loud and if your region is instituting sound regs (most SCCA clubs are) then you will likely have problems. I'd say the hassle isn't worth it - just focus on your driving instead of removing the cat-back before every event.
Old Jul 21, 2010 | 03:27 PM
Rosko350z's Avatar
Thanks for the feedback George. I would not say he's MY competitor. He's really YOUR competitor, plus everyone else who takes STX seriously. As I said, it's the guy who won STX last year in Nationals, the one who beat Jason Isley in the BMW. He's in my SCCA region, obviously a faster driver with a much faster car.
I was just looking for some type of yardstick to shoot for. Even finishing 1.5 seconds off from him would be awesome. So maybe that's what I will shoot for if I ever make it to an event where he is present.
