Starting issue
Old Mar 14, 2010 | 07:06 PM
JGR4444's Avatar
GR
Starting issue
I installed a set of ls2 yukon coils a couple days ago and the car seems to be running a lot smoother. However, i am having problems starting it but it is only when i have been running it. Cold starts, it fires right up... warm motor it will crank but not start... ill let it sit for a second... crank... no start.... let it sit... crank for about 2 seconds and it will fire....
Yes it is grounded correctly and i have TRIPLE checked all the wiring and made sure all the coils matched with the correct spark plugs... i cant figure out what the problem is any ideas?
ouimetnick
25
Sep 14, 2023 01:44 PM
05TR1CH
Apr 18, 2023 04:56 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
SUKIEE
Oct 9, 2017 09:41 PM
