Miss Fire (Automatic 2004 Rx8)
Old Mar 11, 2010 | 08:01 PM
bigfish666's Avatar
hi, ive got a 2004 mazda rx8 automatic, and i was giving it some gas to get up to speed and fro second to third to took a really long time to shift, its like it laged, then the check engine light came on and now it has a miss fire, i got it fixed it cost me 500 bucks, and all they did was change the spark plugs and some wires of some sort, and a couple of days after the same thing happend the check engine light came back on, same miss fire, does anyone know what the hell is going on?
Old Mar 11, 2010 | 08:23 PM
invasion08's Avatar
you need new ignition coils. The dealership just stole 500 dollars from you. Buy the coils online and install them yourself
Old Mar 11, 2010 | 08:54 PM
Old Rotor's Avatar
+ 1 on that...(OEM)plugs,wires,coil,should be $250-300 and you and a buddy could put in takes about an hour. Go back and get the coils in for another 4 or 5 hundred. You could look in the DIY section and do yourself in about half an hour.
Old Mar 13, 2010 | 05:02 PM
04RX8man's Avatar
Rotary Powered Countryboy
yes coils....that should be the first thing changed with a misfire....
Old Mar 13, 2010 | 06:46 PM
lilring's Avatar
Finally a MT
Go with the BHR coil upgrade! You will be extremly happy
Panthersn
Jul 13, 2021 06:30 AM
Redheddude222
Sep 13, 2015 12:57 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
Mr.Durden
Aug 12, 2015 02:21 PM
dmengel
Jul 18, 2015 09:35 AM
