rx8 doing dirt devil sound
Old Mar 11, 2010 | 05:39 PM
low_450's Avatar
Hi , im having a problem every time a start my car when she is cold.I think that its the air pump .My rx8 have 90 000 km and its a 2004.I did a video to show you the problem.I dont know if someone can help me !
http://www.youtube.com/watch?v=u4ZR2KSt-WE
Thank you
Old Mar 11, 2010 | 06:24 PM
the1jesster's Avatar
Trained true Killers
Keep this thread going untill you get help I would like to know what the hell that is
Old Mar 11, 2010 | 06:29 PM
RIWWP's Avatar
A few questions:
1 - Does it do that EVERY single startup? Or does it only do it when starting a 'cold' engine, or only a warm one, or anything else selective about it?
2 - Does it always stop after the same time? Is there any circumstances which might make it last longer or shorter?
3 - Have you tried revving the engine with the noise occurring, does it change pitch or tone with an increase in revs?
Old Mar 11, 2010 | 06:38 PM
outinnowhere3193's Avatar
outinnowhere3193
try unpluging the air pump when it's doing it to see if it stops. then look for something wrong with it. Like lines or cracks. Definitely sounds like a vacuum!!! Motor runs to smooth so it has nothing to do with vacuum lines or the engine it's self. Has to be that air pump.
Old Mar 11, 2010 | 07:41 PM
JGR4444's Avatar
GR
hahaha dirt devil is a good explanation! that thing is loud!
Old Mar 11, 2010 | 08:02 PM
RWatters's Avatar
That's definitely the air pump.
Check this thread out:
https://www.rx8club.com/series-i-tech-garage-22/lost-air-pump-88157/
It gives more information on the air pump, how to remove it, or even how to repair it. I don't believe it's covered under the emissions warranty so you'll be out of luck there.
If you decide you want to replace it hit up http://www.car-parts.com and search for an air pump on there. I just did a quick search and there are TONS of them. Looks like it'll run you $125+ assuming you're in the USA.
Old Mar 11, 2010 | 08:05 PM
Rick's Avatar
I bet it is the lower bearing in the smog pump motor. Take it apart and you'll probably see corosion on the pump and bearing. I've had two go bad, and the picture is from a third one that I purchased. It is not expensive or hard to fix, just do it before the bearing locks up or the motor will fry. Oh, and from now on cover the pump before washing the engine.
Old Mar 11, 2010 | 09:33 PM
low_450's Avatar
Originally Posted by RIWWP
A few questions:
Hi,
1- this happen every time I startup the engine when its cold not when the engine is warm.
2- It sound for always 1 or 2 minutes and after it dissapear
3-Yea i try to rev and the tone stay the same !
Old Mar 11, 2010 | 09:36 PM
low_450's Avatar
https://www.rx8club.com/showthread.php?t=88157
Thanks alot for the site man , today I called the dealer to know the price about the air pump....650 $ CAD DAMNNN
Old Mar 11, 2010 | 10:29 PM
Spinx Haplo's Avatar
Yep, for sure the bearings in the air injection pump. Fortunately if you have a bit of skill, it is easy to replace the 2 bearings in the pump. they are the same size as typical inline skate bearings.
Old Mar 11, 2010 | 10:33 PM
I unplugged that bitch, I don't have a cat anyway. It is coming out soon.
Old Mar 11, 2010 | 11:36 PM
jasonrxeight's Avatar
air pump
either the fan is broken or the bearing
watch this
http://www.youtube.com/watch?v=NPhX638aNLU
Old Mar 14, 2010 | 08:27 PM
low_450's Avatar
I finally solved my problem with the air pump and I didnt spend any money.
I removed the air pump and open it .They were like black dust inside.I clean the interior with varsol and a brush.Everything work find now and i didnt get a check engine after the instalation.I feel very happy because I spend 700$
check out the pictures:
Attached Thumbnails rx8 doing dirt devil sound-pompe-air.jpg   rx8 doing dirt devil sound-linterieur.jpg   rx8 doing dirt devil sound-interieur-1.jpg   rx8 doing dirt devil sound-resultat-final.jpg
File Type: bmp
Old Mar 14, 2010 | 08:34 PM
That's the air valve......must have been stuck almost closed and backed up the pressure into the pump....
05TR1CH
Apr 18, 2023 04:56 AM
ei8ht
Aug 21, 2017 09:08 AM
SupraG
Sep 21, 2015 12:09 AM
ironj221
Jul 16, 2015 10:16 PM
