Throttle Body question
Old Mar 10, 2010 | 03:17 PM
Ru1K's Avatar
I need to clean the Throttle Body on my 8. I bought a Throttle Plate & Carb Cleaner. In the instructions says that I need to turn on the car (not the engine) and press and hold the accelerator to keep the throttle plate open to spray the cleaner inside the TB. If I do that, will be the engine flooded? Can I just push the throttle plate manually to spray the cleaner?
Old Mar 10, 2010 | 03:37 PM
SheffieldSteel's Avatar
Intended acceleration
Quite the opposite. Holding the throttle in is actually part of the recovery procedure for a flooded engine.
Old Mar 10, 2010 | 04:07 PM
TrochoidMagic's Avatar
is adjusting valve lash
RU,
first of all, return that **** and get a "fuel injection" cleaner! carb cleaners may be harmful to some parts and sensors in a fuel injected car. no go...
with the appropriate cleaner spray, you may hold the throttle open manually if you don't mind getting it all over your hands. so wear gloves!
and don't just stop at the TB. unfortunately for rotaries, the junk will travel down the induction system and land on only one side of the rotor face, making cleaning uneven.
being a MAF (mass air flow) sensor'd car, and a rotary at that, cleaning becomes MORE difficult for a thorough job. so it should be followed up with a cleaner in a form of a bottle, a fluid tube and a control ****.
there are various procedures. and the choice of cleaner seems to be "seafoam". so search that up, and find the best procedure that fits your cleaning order. it'll be too long a post to state all possible follow up procedures here...
Old Mar 10, 2010 | 05:27 PM
Charles R. Hill's Avatar
Owner of BHR
Yes, just use a little bit and you'll be fine.
Old Mar 11, 2010 | 01:47 PM
Ru1K's Avatar
In that case I'll follow the instructions, thanks.
I'll use the 3M Do-It-Yourself Fuel System Tune-Up Kit now and the Seafoam after the next 10,000 miles to compare wich one works better for me.
Thanks.
Old Mar 13, 2010 | 05:16 PM
04RX8man's Avatar
Rotary Powered Countryboy
Seafoam ftw!!!!
Old Mar 13, 2010 | 06:58 PM
laythor's Avatar
I zoom therefore I am.
Originally Posted by 04RX8man
Seafoam ftw!!!!
you pour SF in your TB?
Old Mar 14, 2010 | 07:36 PM
Ru1K's Avatar
The seafoam videos on youtube are through the vacuum, engine oil and gas tank.
gwailo
May 14, 2024 06:57 AM
UHATEIT
Mar 31, 2019 05:31 PM
9krpmrx8
Nov 5, 2015 11:45 PM
wayloco
Sep 1, 2015 09:03 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
