alright i need some help
Old Mar 9, 2010 | 03:58 PM
JGR4444's Avatar
GR
View My Video
I have had this problem for a while and have posted a couple threads but i can not figure out what is happening here... my idle is terrible and i cant seem to figure out why. I do not believe i have had any power loss, not any that is noticeable at least and when i am driving everything seems fine... but at idle it is just really rough. I have replaced the spark plugs and new coils are on the way but i dont think that this is the problem... i attached a video at the top of what is does at idle please shoot me some suggestions because i am out of ideas here!
Old Mar 9, 2010 | 04:00 PM
deadphoenix52's Avatar
meh.
clean your MAF
Old Mar 9, 2010 | 04:11 PM
JessiahC's Avatar
Nitrous Threadjacker
Do you have any starting issues?
With it sounding like that, I'd check the fuel pump after cleaning the MAF. I'm surprised it's not throwing a CEL.
Old Mar 9, 2010 | 05:05 PM
JGR4444's Avatar
GR
it is... you just cant see it but im running a straight pipe so thats why it is on.... how do i go about testing the fuel pump if there is such a way
Old Mar 9, 2010 | 05:09 PM
meh.
go get your codes read. the CEL from the straight pipe might be masking another, since you expect it to be there.
Old Mar 9, 2010 | 06:44 PM
JGR4444's Avatar
GR
just cleaned the MAF and its drying now.. also got my codes...
P2070 SSV valve
and P0037 Rear 02 sensor
i already knew about both of these so nothing new here....
just to be sure i did this right, not that its hard to screw up
i took the MAF off and used maf cleaner to spry up the two side tubing of the actual MAF... the resistor looked pretty dirty but i didnt mess with it to much because it looks fragile.. is this all i have to do to clean the MAF?
Old Mar 9, 2010 | 06:47 PM
Jon316G's Avatar
Grasshopper
Yeah... just spray right at the two resistor wires and do not physically touch them.
It evaporates pretty quickly, so it should be fine by the time you install it.
Old Mar 9, 2010 | 06:52 PM
JGR4444's Avatar
GR
Jon man i just watched your video on the DIY for the ssv valve being stuck.. dude your insane! but you just gave me my project for the week since i have a couple days off.. thanks man great write up
Old Mar 9, 2010 | 06:53 PM
Jon316G's Avatar
Grasshopper
Thanks JGR4444.
And you're only 2hrs south of me, so let me know if you need a hand.
Old Mar 9, 2010 | 06:59 PM
JGR4444's Avatar
GR
should i do the 20 break pedal pushes to reset the PCM since i cleaned the MAF or should it be fine?
Jon316G's Avatar
Grasshopper
^May not be a bad idea... why not
Old Mar 9, 2010 | 07:02 PM
JGR4444's Avatar
GR
alright ill do that and take it for a drive... see how the idle issues are... ill be sure to report back with my problems of course
thanks guys
Old Mar 9, 2010 | 09:41 PM
JGR4444's Avatar
GR
alright so the idle problem is 3 times better, it still does it just a little bit though so hopefully my coil install will fix that issue here in the next few days.... just a question though, what exactly does the ssv valve being stuck open hurt? I obviously know that it is not supposed to be stuck open all the time but why is it bad enough to through a cel? just wondering
Old Mar 9, 2010 | 10:25 PM
@!!narotordo's Avatar
FLAME ON!
Read the codes. My air pump went out and thats what my idle was doing. I also have hard start and getting a new engine.
When you install the new coils put some new plugs in too. Give her a good tune up.
Old Mar 9, 2010 | 10:54 PM
Spoolin8's Avatar
check your engine mounts. They can wear out and cause your idle to be ****, ive already had mine replaced 4 times due to them failing.
Old Mar 9, 2010 | 11:08 PM
Jon316G's Avatar
Grasshopper
Originally Posted by @!!narotordo
Read the codes.
P2070 SSV valve
The SSV opens a secondary passage to reduce restriction and increase airflow.
I've seen the "SSV stuck open" code for a valve that was actually stuck closed.
Its more likely for the valve to stick closed since that is how it is when the car isn't running.
There is a N/O impact switch which tells the PCM if the valve is open or closed.
This switch is what generates the CEL... but why is another thing you need to narrow down.
1) If the valve is truly stuck, it won't impact the switch.
2) If the actuator has a pinhole, it won't open the valve.
3) If the solenoid is stuck, it won't allow the actuator/valve to move.
4) If the impact switch itself is bad, it won't sense that the valve has moved.
So before you dig into anything, you need to find out which component is causing your problem.
Old Mar 9, 2010 | 11:41 PM
JGR4444's Avatar
GR
and all this i can tell by taking apart the housing correct?
Old Mar 9, 2010 | 11:42 PM
Jon316G's Avatar
Grasshopper
What do you mean by "housing"?
Old Mar 10, 2010 | 12:43 AM
FLAME ON!
You dont need to remove the head or pistons to do this
Old Mar 10, 2010 | 09:08 AM
JGR4444's Avatar
GR
haha very funny... i meant by taking the ssv valve out in your diy jon
Old Mar 10, 2010 | 06:39 PM
JGR4444's Avatar
GR
so i installed my ls2 coil kit today and everything seems to be running a lot smoother but starting the car is now pretty tough... i cant figure out why but it will crank for a while and not start... and i have flooded the 8 before so i know what that is like, this is a different kind of no start... any suggestions... it was fine before i put the kit in
Old Mar 10, 2010 | 06:44 PM
Jon316G's Avatar
Grasshopper
Ah... no, removing the valve will not give you better access, removing the upper intake manifold will.
You can check everything with the valve still installed and I highly recommend that you don't remove the valve unless you're sure its the culprit.
Is this from BHR?
If so did you follow their directions and use a good grounding point?
Old Mar 11, 2010 | 03:59 AM
FLAME ON!
Hard start could be a few things.
Battery
Starter
New engine.
Old Mar 11, 2010 | 06:55 AM
JGR4444's Avatar
GR
Battery
Starter
New engine.
not trying to be rude here man, but do you know how to read or are you just being ignorant and not reading the rest of the thread because if it was starting fine before the coil install and now its having a rough time starting then obviously something went wrong with the install. Dont give poor advice to boost your post count it doesnt help either one of us.
Old Mar 11, 2010 | 07:29 AM
JGR4444's Avatar
GR
Is this from BHR?
i dont think i grounded it very well at first but i took it back off and grounded it the cross rail beneath the plastic tray that is supposed to be underneath the airbox.. but i took that out so the rail is just sitting right there and other things are grounded to this so i thought it would be a good idea to ground my wire to that also.. but i still had a rough start this morning... i cant figure out whats going on
UHATEIT
Mar 31, 2019 05:31 PM
Dokuji
Nov 1, 2016 02:51 PM
Forevermore
Sep 20, 2015 01:04 PM
KYRX8
Nov 18, 2004 03:39 PM
