prosport gauges
Old Mar 6, 2010 | 01:35 PM
kennyt2001's Avatar
prosport gauges
I am planning on putting gauges in my rx8 and was wondering if the prosport gauges come with all the hookups for like the boost lines and oil lines. And also what three gauges are typically used for monitoring
Old Mar 7, 2010 | 05:10 PM
Loki's Avatar
I had these on my old car. Very happy by the way, good product as far as I'm concerned. They do come with sending units and necessary wiring where appropriate. Take electrical gauges where possible, much easier to set up when dealing with oil and water lines. I think I even saw their own wideband 02 controller on the site recently.
Is the car stock? Oil temp and pressure are a good idea, as for the third.. coolant temp? vacuum?
Old Mar 7, 2010 | 06:18 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^BOOST
Old Mar 7, 2010 | 06:43 PM
kennyt2001's Avatar
i got turbo kit in hand, just getting all the other things like gauges and stuff together before the install. also trying to figure out where to mount the gauges because I have nav and the RB pod looks like it comes in a assembly. dont really want to spend 450 bucks when all i want is the pod
Old Mar 7, 2010 | 06:44 PM
mscamp02's Avatar
Blue Bullet?
you can order just the pod, but I wanna say 100+ for it, not sure.
I know rotaryfx.com has it instock
Old Mar 7, 2010 | 07:26 PM
kennyt2001's Avatar
nice thanks mscamp for the the link to the pod, that makes life easier for me now
Old Mar 9, 2010 | 02:52 AM
Trying to determine if I can just pirate the OE engine coolant temperature sensor signal rather than installing a separate aftermarket one. I don't like where the additional aftermarket sensors mount. The best spot is where the OE sensor is in the front cover housing.
cliffkemp
Dec 24, 2024 10:48 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
JantzenRX-8
Oct 4, 2015 11:30 PM
