best spark plugs to buy for the rx8
Old Mar 2, 2010 | 10:09 AM
REAL_SPEED723's Avatar
need to replace my spark plugs cuz i think they may be the reason why my car isnt turning on right away. every time i turn the key it sits there a couple seconds before it turns over, so figured a good place to start would be with the spark plugs.
from what i can see a lot of people are going with NGK Laser Iridium Spark Plugs, are these the best ones to get??
any input would be cool. thanks
Old Mar 2, 2010 | 10:24 AM
CRO8TIA's Avatar
Are you saying when you turn the key , there is a delay to the starter turning over, or that the motor turns over but takes a few seconds to fire ?
Old Mar 2, 2010 | 11:41 AM
Huey52's Avatar
Registered Zoom Zoomer
I use the NGK in my NA application (FI requires a 'cooler' RX-7 type plug).
NGK Racing plug 6700 RE7CL .048 Leading $20.55 (L = Leading)
NGK Racing plug 6701 RE9BT .048 Trailing $20.55 (T = Trailing)
Above from sparkplugs.com, although BHR here often has better prices.
Old Mar 2, 2010 | 01:56 PM
ya i turn the key and it turns over but takes a few seconds to fire
Old Mar 2, 2010 | 01:59 PM
HomicidalApple's Avatar
Yea id ask BHR before anything.
Real im digging the headlights, those are intense. You should pm me how you did that so i dont s**t on your thread.
Old Mar 12, 2013 | 03:50 PM
Johnman's Avatar
Did you ever fix the issue? My rx8 does the exact same thing.
Old Mar 12, 2013 | 04:04 PM
wcs's Avatar
wcs
no agenda
LOL you just bumped a 3 year old thread
I wonder if the OP is still around
edit:
There are quite a few items that can cause hard starts
Coils
Plugs
Clogged Cat
Low Compression
Worn out starter or using the old model starter from the 04-05's
Just to name a few
Old Mar 12, 2013 | 07:43 PM
get a new starter, problems solved.
Old Aug 29, 2013 | 08:08 AM
Amethyst643's Avatar
04 08 Mazda RX8 NGK Racing Wires Laser Iridium Spark Plug KIT Free Emblem | eBay
Here the whole set with wires is $89.99.
Zank300
Aug 26, 2015 07:40 PM
Obivious
Jul 29, 2015 05:57 PM
thedragonrotar
Jul 22, 2015 08:46 PM
Belalnabi
Jul 17, 2015 07:48 PM
AussieGray
Jul 16, 2015 03:58 AM
