West RX-8 Forum Serving CA, NV, AZ, HI
SM/LA no0b needs help.
Old Feb 27, 2010 | 02:38 PM
bapexnbhd's Avatar
Red face SM/LA no0b needs help.
has anyone deflooded an rx8 before? i had my baby sat for 2 weeks and now it doesn't fire up. i have tried cranking the car n had aaa come to jump start the car n it still didn't work. I called mazda dealership to ask if my "total care" warranty covers it, but they said they can't tell until they inspect it.. and the inspection costs 95$!!!! not to mention the full service dealership is in alhambra, towing service would cost another two hundred.
so is there anyone in santa monica/los angeles area can help a rx8 fellow to deflood my car? I can pay. Thanks.
Old Feb 27, 2010 | 07:21 PM
dopeyxhj's Avatar
take it to dealer.
dealer will covers for towing.
flooded my rx8 twice 2010.
Old Feb 27, 2010 | 07:43 PM
socalrotor's Avatar
_
fill up the gas tank on my nissan 200 sx and I can hook it up.
Old Feb 27, 2010 | 09:39 PM
bapexnbhd's Avatar
that's a fair deal. have you done it before though? i will only pay if it's fixed..
Old Feb 27, 2010 | 10:55 PM
socalrotor's Avatar
_
I understand, and that totally reasonable. I have unflooded 2 rx8's and countless rx-7's. I have been on the 7 club since 05 and have personally owned 6 FC's. Here is what the plan is, we will pull the plugs and 20 amp fuel pump fuse as a start. Can you get a new set of plugs to replace the fouled set when we get it running? Sound ok? Is the battery dead?
Old Feb 28, 2010 | 12:59 AM
If it's a MT...tow start it...it will take less than a block and start easily...expect a smoke show that would put the fire dept to shame
If it's an AT...all bets are on doing it the hard way
Old Feb 28, 2010 | 03:47 AM
bapexnbhd's Avatar
i'm not only a noob to rx8, but cars..
i don't know where to get new set of plugs, do you have an extra set? I will pay for that, too. I'm pretty sure the AAA guy told me it's not the battery problem..
So are you free tomorrow to unflood my car?
Old Feb 28, 2010 | 08:35 PM
socalrotor's Avatar
_
Dealer will have the plugs, I gotta do a set of coil overs on a car in the afternoon tomorrow, are you free in the mid morning? Your in Santa Monica right? 6mt?
Old Feb 28, 2010 | 09:50 PM
bapexnbhd's Avatar
yes, my car is 6mt. n my zip code is 90025.
mid-morning would be fine.. my classes start at 2:15pm..
Old Feb 28, 2010 | 11:01 PM
socalrotor's Avatar
_
Ok I will leave Gardena around 9ish. So your right off the 405, anywhere you want to meet? Or you can just PM me the address, what ever you prefer.
Old Feb 28, 2010 | 11:31 PM
bapexnbhd's Avatar
dang.. i thought ur actually in SM..
that sounds good.
how long does it usually take to get it fixed?
pm-ed address
p.s you don't have school or work?
Old Feb 28, 2010 | 11:39 PM
socalrotor's Avatar
_
Pm 'ed ya back......I am on unemployment at the moment TBH. Not much ad work till spring so every tank of gas helps.
Old Feb 28, 2010 | 11:54 PM
bapexnbhd's Avatar
let's hope it will work
Old Mar 1, 2010 | 11:08 AM
socalrotor's Avatar
_
Hey bro, there is a wreck on the 405N I am going to hold off till 9:30 to leave.
Old Mar 1, 2010 | 04:20 PM
socalrotor's Avatar
_
UPDATE
Battery was under 11.5 volts and wouldn't take a charge. I was the OEM from the factory. Starter is acting up, it will throw the pinion gear out, but the motor doesn't turn. We had to bump the car in gear to move the flywheel to get to engage and turn everytime. Swapped to a good battery and cracked it with the 20 amp fuel pump fuse pulled. Car wouldn't even cough and smelled up the joint with fuel. Pulled the plugs and turned it over to clean her out. Torched the plugs with a lighter and reinstalled them. BTW they looked new. Turned it over and it gave a half a cough. Tried it a few more times and the starter was acting up almost every time. Now I am wondering if the starter is not turning over the motor quick enough to fire. Another problem, car is in an underground parking garage so it is not possible to push/ drag start it. UGH!!! The car has the total care warranty so the next move it to call the dealer to see if it is covered without the worry of the $95 inspection fee. Any thoughts?
Old Mar 3, 2010 | 03:08 AM
bapexnbhd's Avatar
UPDATE
hey bro,
do you think we can work it at night tomorrow? cause I'm getting a ride from eric to go to school.. so we'll probably leave at 11.. doubt we can get it working in an hour?
Old Mar 3, 2010 | 03:51 AM
bapexnbhd's Avatar
... or thursday ?
Old Mar 3, 2010 | 06:54 AM
scremn8's Avatar
the more things change
need two battery's to turn it, or one really strong battery.
if you have an 04 or an 05 then it's the old starter and needs
either a really strong battery or both.
ive flooded my car more time then i can count.
but the battery is the key. i have a red top.
Old Mar 3, 2010 | 01:03 PM
socalrotor's Avatar
_
We got a new battery, and I am with you on the starter seems slow on the crank over. IIRC car is an 04.
Old Mar 4, 2010 | 01:39 AM
bapexnbhd's Avatar
hey steve u comin tmr?
Old Mar 12, 2010 | 03:13 AM
bapexnbhd's Avatar
UPDATE: gave up trying myself. have it towed to the dealer today.. hopefully the warranty covers it and i will get her back on saturday...
Old Mar 12, 2010 | 02:27 PM
bapexnbhd's Avatar
they just told me inspection fee for regular mazdas cost 95.. but for rx8, it costs 190.. WTF? damn stealership.. )(#@!)(&*@!$!@&)@!*#)(@*#)
Old Mar 12, 2010 | 09:51 PM
bapexnbhd's Avatar
problem solved. the warranty covers the floodin problem but charged me 450 to fix the coil ignition... that's the reason why it takes longer to fire up my 8... damn, i'm broke :\
Old Mar 14, 2010 | 06:22 PM
Rotary__Rocket's Avatar
All Show All Go
opps...it only cost 100bucks for a new set of coil...
for this price, you probably should hv gone BHR...
Old Mar 14, 2010 | 06:23 PM
All Show All Go
hey btw congratz for the new ride!
