maf sensor cleaners question
Old Feb 25, 2010 | 01:24 PM
gregs's Avatar
Pull My Finger
i have been wanting to clean my maf sensor as a preventative measure but i have been told our sensor has a delicate coating for protectant and if electronic sprays are harsh it may strip that protective coating..my question is any of you guys experience maf issues after cleaning? any recommended over the shelf cleaners work best?
thanks
Greg
Old Feb 25, 2010 | 01:33 PM
Greg,
I've cleaned my MAF sensor quite a few times and never had issues with an over the counter MAF cleaning spray. Just don't go nuts with the spray and you'll be fine.
Old Feb 25, 2010 | 01:36 PM
RX8YA's Avatar
WAH WAH WAH
Ive cleaned mine a few times with spray found at your local parts store (Napa, Autozone, pepboys) I had no issues at all.
Old Feb 25, 2010 | 01:39 PM
gregs's Avatar
Pull My Finger
great thats what i was looking foward to hearing. making sure by cleaning it does not shorten the lifespan
Old Feb 25, 2010 | 01:44 PM
I don't scrub the MAF at all. I know some people like to use a small q-tip or something to better clean a MAF sensor but I wouldn't recommend that. It cleans just fine with the spray.
Huey52's Avatar
Registered Zoom Zoomer
MAF cleaner spray at Autozone or the like, or Electronics Cleaner.
You want a spray solvent that fully dissipates and doesn't leave a residue, so don't use WD-40 or similar.
Old Feb 25, 2010 | 01:50 PM
Brettus's Avatar
Boosted Kiwi
Used CO contact cleaner a number of times without issue .
Old Feb 25, 2010 | 01:54 PM
NgoRX8's Avatar
I've cleaned my maf a couple times with maf cleaner as well with no issues.
Old Feb 25, 2010 | 02:35 PM
UrbanOcho's Avatar
Stick Specialist
Warning, here comes a bimbo question. where is the maf sensor located?
Old Feb 25, 2010 | 02:37 PM
Vlaze's Avatar
The Angry Wheelchair
On the intake accordion tube. It's in the bracket piece mounted up on top in the middle of it with 2 bolts and wires coming from it, can't miss it
Old Feb 25, 2010 | 02:39 PM
NgoRX8's Avatar
On the tube attached to the intake box. Right before the accordion rubber tube. It is screwed on with 2 small philips head screws.
Old Feb 25, 2010 | 02:40 PM
lilring's Avatar
Finally a MT
I have cleaned it with Qtips. It works good!
Old Feb 25, 2010 | 02:41 PM
Easy_E1's Avatar
Old Feb 25, 2010 | 02:43 PM
UrbanOcho's Avatar
Stick Specialist
thanks vlaze and ngo, now I can say I've learned something today. I've got my can of spray and my philips head screwdriver, so now i'm ready to roll.
Old Feb 25, 2010 | 02:45 PM
Vlaze's Avatar
I believe there is a DIY on this with pictures in case you get lost
Old Feb 25, 2010 | 02:47 PM
UrbanOcho's Avatar
Stick Specialist
I searched but was not able to find it in the DIY forum.....
Old Feb 25, 2010 | 02:52 PM
Vlaze's Avatar
Found this through a little searching
Look at post #19
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-how-clean-maf-94872/
Old Feb 25, 2010 | 03:15 PM
Huey52's Avatar
DIY thanks to Jon (I like pictures too) https://www.rx8club.com/showpost.php...71&postcount=9
Old Feb 25, 2010 | 09:18 PM
Q tip and rubiing alcohol works fine.
Old Feb 26, 2010 | 12:27 PM
UrbanOcho's Avatar
Stick Specialist
I think even a blonde could do it with those directions and photos, LOL
I have a suggestion - now that Vlaze and Huey did all the hard work of digging up the posts on a MAF cleaning procedure, how about the mods fixing it all up and posting us an easy-to-find thread in the DIY forum.
Old Feb 26, 2010 | 01:32 PM
UrbanOcho: just PM Zoom44 and have him add it to the DIY list sticky thread.
Old Feb 26, 2010 | 01:47 PM
epikeddie's Avatar
UrbanOcho,
It's a very simple 15-20 minute procedure. Generally, when oil or other residue pass through the air filter, it usually ends up coating the MAF sensor. The sensor is housed in a black plastic piece with a tube protruding out from the base (you can't see this tube until you unscrew the two phillips screws and pull the MAF sensor out.
1. Unscrew the two phillips screws that are securing the sensor to the intake tube. Pull the sensor out by pulling the entire sensor towards yourself. If it's been on there for a bit, it may require some wiggling. Be gentle and don't bang the sensor anywhere, the MAF sensor on any car is rather quite delicate and can cause all sorts of issues if damaged.
2. Look into the tube on the MAF sensor. You'll notice one-half of the tube has two small wires parallel to each wires. There's your MAF sensor! Congrats, you found it!
3. Now take your MAF cleaner and gently spray the wires. I like to make sure that stream isn't too abrupt and give it a half-effort spray - coating the two wires completely.
4. MAF cleaning sprays dry very quicly. So depending on how much you sprayed, make sure to let the sensor dry completely.
5. Reinstall using the steps reversed. When you're putting the MAF sensor back in, make sure that the connector side is on the right as it was before you took it off.
6. Start the car and enjoy your smoother idle!
ironj221
36
Jan 20, 2026 08:28 PM
uZu
Dec 30, 2015 12:35 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
tgaffner
Aug 20, 2015 10:55 AM
Eirulisse
Aug 15, 2015 12:34 PM
