engine prob
Old Feb 23, 2010 | 01:31 AM
jsmRx8's Avatar
engine prob
hi every one i picked up my 8 from the body shop today and they said that the engine light had popped on during its month there. when i drove it home the idle was way low. i had to rev it to keep it from dying. when i got home its about 12 mi away i popped the hood and some steam (i think) came out. also engine fluid had leaked out from my overflow. it is an 05 mt wit 82000 mi on it. help!
Old Feb 23, 2010 | 01:36 AM
Pick a thread
Old Feb 23, 2010 | 01:38 AM
zoom44's Avatar
where do you live? why did you have it at the body shop? how many times did they flood it while they had it for the month? what's the cel code?
jsmRx8's Avatar
ha my bad
Old Feb 23, 2010 | 01:41 AM
jsmRx8's Avatar
im in norcal it was at the body shop to get a ms bumper on it as well as fix a fender. i dont think they flooded it and whats the cel code?
Old Feb 23, 2010 | 01:44 AM
They might have overfilled the rad.....
If they fouled the plugs you will need to drive it hard for more than 12 miles before they behave again....if they are old plugs throw in a new set...
Otherwise...list specifics and then we can help
Old Feb 23, 2010 | 01:46 AM
jsmRx8's Avatar
cool what kind of specifics?
Old Feb 23, 2010 | 01:49 AM
zoom44's Avatar
the engine light is a "check engine light". when its on the computer has determined that some sensor has detected a problem. so it turned on the light and stored a "Check Engine Light" code in its memory that can be read and helps diagnose what is wrong.
In order to diagnose the car we need some info in the form of that cel code. go to an autozone or some other shop and ask them to get the code for you. the connection point is under the dash below the steering wheel.
Old Feb 23, 2010 | 01:56 AM
jsmRx8's Avatar
well sounds like im off to the dealer ill be back and thanks. feel free to post other ideas though
Old Mar 7, 2010 | 08:03 PM
jsmRx8's Avatar
ok so i went to the dealers and they said it was the coils so i replaced them along with the plugs and wires. my idle is getting bad though. the car idles fine until it warms up and then it will fall and die. help
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
cschoeps
Aug 6, 2015 12:44 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
