Premixing Supertech TC-W3 from Walmart??
Old Feb 21, 2010 | 10:49 PM
prighello's Avatar
Has anyone used this stuff when premixing? Is it okay to use? The package says it uses an anti gel formula to prevent clogging injectors. Sounds like this might be a useable product. I'm not that knowledge regarding oils and I know there are a lot of differing opinions here on the forums about what is okay to use. I have attached the MSDS in case that can help answer the question
File Type: pdf
Old Feb 21, 2010 | 11:24 PM
You can use it but really you want a Jaso-FD rated 2 stroke, not a TCW3. This won't hurt but there are better alternatives. But if money is an issue ten by all means use it. My only complaint about the Marine stuff is that it caused my car to smoke a bit. But any premix is better than none
Old Feb 22, 2010 | 12:50 PM
prighello's Avatar
Will it smoke if one is using a cat?
Old Feb 22, 2010 | 01:02 PM
Not sure, I am catless.
Old Feb 23, 2010 | 11:03 AM
prighello's Avatar
Will a TC-W3 oil damage the cat? Is that why you are catless? I can't run without a cat in California; it is illegal.
Old Feb 23, 2010 | 11:13 AM
Supposedly TC-W3 can hurt the cat converter but then some old rotor heads say that is BS and teamrx8 posted pictures of his cat and it was clean as a whistle and he premixed so I kind of doubt it hurts cat converters.
OnebaddRx8
Aug 25, 2019 11:34 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
R3Dream
48
Mar 12, 2016 01:44 PM
tommy26Germany
Sep 29, 2015 10:33 AM
