Can you still get a recalled engine?
Old Feb 20, 2010 | 12:54 PM
Tweek's Avatar
RobotsToRobots.com
I know there are plenty of recall threads, but nothing from this year.
I feel plenty of vibrations at idle in my seat, and im told thats one of the symptoms.
I bought my 04 RX-8 used 2 months ago, if i go to the dealership can they still run tests to see if i need the new engine? Or was that only for a certain period of time back in 06?
Old Feb 20, 2010 | 12:56 PM
Spinning Sushi's Avatar
I <3 Sushi
You can always go to the dealership and run tests... but they'll charge you a pretty penny if you're out of warranty.
Old Feb 20, 2010 | 12:57 PM
Tweek's Avatar
RobotsToRobots.com
I have 60k miles, 100k is the warranty right?
Old Feb 20, 2010 | 12:58 PM
I <3 Sushi
Yep, and if it's not a bad engine then you'll have to pay for the tests. They waive the fees only if they discover it's a bad engine.
Old Feb 20, 2010 | 12:59 PM
Tweek's Avatar
RobotsToRobots.com
How much are we talking?
what are other symptoms of a bad engine?
Old Feb 20, 2010 | 01:00 PM
I <3 Sushi
It all depends on the dealership. I've seen stealership prices as high as $800.
Old Feb 20, 2010 | 01:01 PM
Tweek's Avatar
RobotsToRobots.com
wow..
Any other way i can test for a bad engine?
Old Feb 20, 2010 | 01:02 PM
I <3 Sushi
What I would do is find a nice little rotary shop and have it tested there for about $50-100. If the results are bad then bring it to Mazda.
Old Feb 20, 2010 | 01:04 PM
Tweek's Avatar
RobotsToRobots.com
Alright thanks a lot, hopefully mazda isnt full **** and after i get it tested at a rotary shop, they tell me its fine and charge me >.>
Old Feb 20, 2010 | 01:05 PM
I <3 Sushi
Try calling up your Mazda dealership first and see how much they charge for a compression test.
LGukas's Avatar
usually they charge something around 100$.
Old Feb 20, 2010 | 03:56 PM
alnielsen's Avatar
That vibration can be caused by a bad motor mount too.
Old Feb 20, 2010 | 04:45 PM
04rx8kid's Avatar
even if you get it tested at a local rotary shop and take it to mazda they will just say they will have to retake the test and do it themselves, thats what my mazda dealer said when i took my compression test results in with low compression, although not low enough to get a new engine.. yet
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
9krpmrx8
Nov 5, 2015 11:45 PM
Rx808BI
Aug 9, 2015 10:06 AM
