Anyone running without an OMP?
Old Feb 17, 2010 | 01:44 PM
TheWulf's Avatar
My 8 looks like a Smurf
Just wondering if anyone is running pure premix, no OMP?
I'm currently running the Sohn adapter and considering removing the OMP altogether and sticking to premix.
I know I could probably just leave the OMP on and just unplug it, but I was wondering if anyone ripped the whole thing out and if so, how you sealed everything up (just gasket, sheet metal and screws?) and if you ran into any problems.
Old Feb 17, 2010 | 01:47 PM
I know you would get codes and I am pretty sure your car would run in limp mode. There is a guy working on something like this do to the location of his Turbo to the factory OMP location. Search for his thread.
Old Feb 17, 2010 | 02:23 PM
TheWulf's Avatar
Codes are fine, I can mask those. Since the AP can control OMP levels, I'm hoping it can set them to 0 and bypass limp mode.
I'll try to find the thread.
Old Feb 17, 2010 | 02:29 PM
Found it!
https://www.rx8club.com/showthread.p...t=oil+metering
Old Feb 17, 2010 | 02:39 PM
Highway8's Avatar
Registered RX8 Nut
I dont know where but I read that it is better to use the OMP. If you only run pre mix, you only get oil when the injectors are firing. So imagine what is happening when you let off the throttle at 9K RPM. Yep thats right, no fuel so no oil either.
Old Feb 17, 2010 | 02:53 PM
MazdaManiac's Avatar
Removal of the OMP will generate a limp mode/code that you cannot override with the AccessPORT or any other flashing tool.
The OMP must be present and plugged in, even if it is not functioning.
GTAW is working with a deletion.
And no load as well. The residual oil is probably plenty.
That said, I don't really understand the point of deleting the OMP - it works and if it is i the way of your FI fabrication, hire a better, more imaginative fabricator.
Old Feb 17, 2010 | 03:04 PM
TheWulf's Avatar
Originally Posted by 9krpmrx8
Thanks! Great thread.
Looks like you are correct.
Originally Posted by MazdaManiac
Originally Posted by olddragger
one thing i dont like about not having the omp----is during high load/high rpm--you let off the gas and very little lubrication is getting to the seals.
This is like on track use or mountain driving---idle amount of premix going in but engine is at a much higher rpm.
I agree with Dan--let pre mix be a supplement.
OD
Yes, this is my main concern after all the EMS headaches.
Enlightening discussion. Thanks guys!
Old Feb 17, 2010 | 03:13 PM
TheWulf's Avatar
For me the idea was to remove clutter from the engine bay and just simplify the entire thing. Cleaner layout and less points of failure, especially since I already premix anyways, less things to check.
Didn't think it would cause this many issues as it's a popular mod with 7s.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
