Noise without cat
Old Feb 14, 2010 | 01:35 PM
Avalanx's Avatar
Noise without cat
Hey,
It seems that my stock cat is damaged and I may need to replace it, but I was considering just removing it. I still have the stock is exhaust, is this a good idea?
More importantly how much louder does it make the car, because I seen some vids and the rx8 is really loud without the cat, is this true?
Old Feb 14, 2010 | 01:44 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
There are a couple guys running race pipe to oem muffler, ask dozer, I believe I read that he subscribes.
I have a turboxs set up that I don't like and is coming out (already sold) and driving to cincinatti to get an AP exhaust + mid pipe so I wouldn't know. I only had the stock muffler on 4 2 months.
Should be fine though, it will also help you pop some flames!
Old Feb 14, 2010 | 01:47 PM
pup's Avatar
pup
holla if u hear me
get a high flow cat or a straight pipe.....mines a little raspy....i have a straight pipe......i might try sumthing different or get a resonator......youtube has all sorts of videos u can listen to
Old Feb 14, 2010 | 02:04 PM
Spoolin8's Avatar
The AP with the AP dual res is loud and raspy. I have heard the xs power setup and it was quieter and less raspy then my AP + AP dual res. I finally switched my AP mid pipe to a RB dual res midpipe and it sounds amazing now.
Old Feb 14, 2010 | 02:13 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
word. I'll keep that in mind.
Old Feb 14, 2010 | 02:57 PM
RX8YA's Avatar
WAH WAH WAH
I have the AP dual res pipe with greddy sp2 I can tell you the AP dual res is raspy especially between 3500 and 4,300 when you are putting load on the throttle if you can deal with that tiny aspect its alright.
Old Feb 15, 2010 | 10:36 AM
jfxp's Avatar
Rotor nut
You will not damage the car by removing the cat. You will have a CEL light on your dash by going with a strait pipe. Yes, it will be loud.
Old Feb 17, 2010 | 07:15 AM
SleepeR1st's Avatar
^^ A local NH member has a gutted cat on the stock intake. Sounds better, a little raspier, but not loud by any means. Sounds mostly stock.
mdl0209
May 23, 2019 05:46 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
Jb4ker96
Sep 27, 2015 10:06 PM
