electronic throttle control
Old Feb 10, 2010 | 03:06 PM
stickmantijuana's Avatar
Unregistered User
is rx8 electronic throttle control a standalone unit (other than being controlled by the ecu) that can be mated to rx7 throttle body shaft with a simple custom bracket connected to the original rx8 ecu?
and which input signals do rx8 ecu need to make electronic throttle control function?
Old Feb 10, 2010 | 06:52 PM
In short : No, you can't.
you need way more than just the TB and ECU. Its just not worth it.
Why would you want Drive by Wire system? Its only here so "stability control" kind of system will work.
Old Feb 10, 2010 | 07:50 PM
MikeTyson8MyKids's Avatar
That and the redundancies now built into the drive-by-wire system.
Old Feb 11, 2010 | 05:18 AM
Unregistered User
sorry I wasn't clear.
I have an RX-8. I'm doing 20b swap with Rx7 throttle body. I want to keep using the rx-8 electronic throttle control instead of using the throttle cable. I no longer have all my rx8 stuff, so I wanted to ask whether electronic throttle control on rx8 can be easily adapted to the rx7 throttle body.
thanks!
Old Feb 11, 2010 | 06:57 AM
dznutzuk's Avatar
Uncontrollable drifter
Nope you can't use it, worthless piece of plastic. Get a pedal from a 2nd generation rx7, drill a hole and DO IT, DO IT.
Old Feb 11, 2010 | 11:09 AM
What ever you do... don't get a TB assembly from Toyota.
cliffkemp
Dec 24, 2024 10:48 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
D13
Oct 1, 2015 07:55 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
