Has anyone done there own 30K service?
Old Feb 8, 2010 | 02:11 AM
Spectre5's Avatar
Hey everyone. I'm planning to do the 30K service on my vehicle myself - to save a little money (hopefully?) and mostly to learn more about my car. I've done a lot of reading through the manual and DIY section on the forums. I was wondering who else has done the 30K service on their car already? What needs to be done, where is the best place to buy the stuff, and most importantly, how do you "prove" the work was done to keep warranties intact?
From the Mazda manual and some "menus" for the service I've seen, this is the list I've compiled so far (besides regular oil changes, I've done no other servicing on the car):
Oil/filter change
MAF air filter cleaning
Replace air filter (suggestions?)
Replace cabin air filter (suggestions?)
Replace spark plugs (suggestions that keep warranty in-tact?)
Replace manual transmission fluid (manual says it isn't needed until 60k)
Replace rear differential fluid (manual says it isn't needed until 60k)
Check/add brake/clutch fluid
Clean battery terminals (with what, is a wire brush OK?)
Grease locks/hinges (what kind is best?)
Then there are a few things I don't think I can really do (mostly inspections since I don't know what to look for exactly...):
Wheel alignment (I'll just wait til I get new tires which will be really soon)
Inspect Drive Belt (I wouldn't know what to do)
Inspect fuel filter/lines/hoses/etc
Inspect cooling system
Inspect brakes/brake lines
Inspect suspension, ball joints, steering linkages, etc)
Inspect drive shaft dust boots (??)
Other inspections...
Cooling system "pressure" test (what is it?)
Then I don't think these are needed:
Flush/Replace coolant (manual says not until like 60k?? - I had to add some at one point when the light kept coming on though)
Replace fuel filter (should I?)
Flush brake fluid (should I?)
Coils/Wires (do I need to replace these with the spark plugs??)
So - how does this list look? What needs to be changed/added/removed? What places (online or offline) do people suggest for the best prices, and to repeat - how do I prove the work was done so the warranties stay intact?
And finally, for the things I can't do myself, what do you suggest? Should I take it to a dealer or somewhere and ask them just to do all the inspections? I'd guess they would still charge me an arm a leg just for that though...
Old Feb 8, 2010 | 03:19 AM
shadycrew31's Avatar
WENTGERMAN
Oil/filter change Y
MAF air filter cleaning Y
Replace air filter (suggestions?) Y K&N pannel filter
Replace cabin air filter (suggestions?) ehh
Replace spark plugs (suggestions that keep warranty in-tact?) Y
Check/add brake/clutch fluid Y do this when the car is level
Clean battery terminals (with what, is a wire brush OK?)Y
[B]Inspect usually means make sure there aren't any leaks most of that stuff they don't even look at.[ when you have the car in the air just look around for anything leaking./B]
Flush/Replace coolant (manual says not until like 60k?? - I had to add some at one point when the light kept coming on though) Y becuase its easy and why not
Coils/Wires (do I need to replace these with the spark plugs??) Y and N its your call.. if your having rough idle issues you may want to look into doing those or upgrading to the bhr kit and never having to service it again.
anything that I've left blank dont bother with unless your getting issues.
Have fun!
Search around for any other questions you might have so the boards don't get flooded with thread upon thread of maintenance questions.
Old Feb 8, 2010 | 03:22 AM
WENTGERMAN
P.S. you can do most of this maintenance with a 10mm, 12mm, spark plug socket, and a Philips screwdriver. Like I said just search.
Old Feb 8, 2010 | 07:38 PM
epikeddie's Avatar
You should do EVERYTHING on that list.....
Everything is rather easy to do yourself with basic tools. There are also a lot of DIY threads on this forum that explains step-by-step. Just use the search function for a specific task.
Also, coils are our weak link in this car. Poor ignition will lead to misfires, bad MPG, and eventually a failed catalytic converter.
At 30k miles, you should replace the coils regardless while replacing your spark plugs. Get the BHR kit if you plan to keep the car for a bit and don't want the hassle of failed OEM coils.
Old Feb 8, 2010 | 08:56 PM
Don't believe any of the posters.
Everyone who has an RZ8 has brought their car in for a 30k service.
WE do not violate the falsely belived Global warming.
We are afraid of the Green Police.
NOT
Old Feb 8, 2010 | 09:30 PM
Spectre5's Avatar
I've heard about the BHR ignition kits --- will it void any warranty? I was thinking of just using some OEM or similar one to make sure I don't void any warranties?
Shankapotamus3
Mar 14, 2021 03:53 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
JCTaylor
Sep 30, 2015 07:31 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Stubbs
Sep 27, 2015 04:06 PM
