Sways or springs first?
Old Feb 3, 2010 | 10:08 AM
Pendleton's Avatar
Roto-rookie
If I can only afford to do one mod, which will be more beneficial to handling? Sways or springs? As far as springs go, I don't want much drop, so I'm thinking H-techs. I've done the drop thing before in previous cars and I'm sick of worrying about scraping/bottoming out.
Old Feb 3, 2010 | 10:20 AM
JinDesu's Avatar
went back to srsly broke
What are you feeling when you are taking the corners? Does the car feel floaty? Did you want your turn-in to be crisper?
Most people probably would feel sways better because it reduces the body roll and improves your turn-in. However, since sway bars tie your left and right sides together, heavy turning can lift your inside wheel.
Springs will reduce body leaning in corners, but can cost ride quality. Might not be much depending on your spring/shock setup, but it will since aftermarket springs are stiffer than stock.
Old Feb 3, 2010 | 11:31 AM
epikeddie's Avatar
I would say the sway bars first.
When I got my JIC FLT-TAR coilovers, they were a HUGE improvement over stock, but at a price of $1700+.
When I got my Progress Technology sway bar set w/ AP endlinks, they were also a HUGE improvement over the stock pieces. But this time.....the cost was only $300+.
If you want to FEEL the improvement right away, then go with the sway bars. If I had to do it all over again, I would've went that route.
Old Feb 3, 2010 | 11:53 AM
TopGear8's Avatar
mkuhnracing.com
Sway bars will give you the better benefit.
Old Feb 3, 2010 | 12:07 PM
Pendleton's Avatar
Roto-rookie
Thanks, that's just what I needed to know.
I don't feel "floaty" through corners at all, just a bit of body lean that I'd like to eliminate.
So I'll probably go with sways first. Don't know if I'll spring for adjustable or not, as I don't track the car and would probably drive myself nuts trying to figure out the right setting anyway.
Old Feb 3, 2010 | 12:18 PM
Springs help for weight shift under hevy braking and acceleration.
You don't need those.
Sway bars are for lateral shift which you can feel every day if you drive it hard.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
duworm
Oct 1, 2015 04:57 PM
Steve Dallas
Sep 19, 2015 09:39 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
