Cutting the front grille?
Old Jan 30, 2010 | 12:35 AM
rotary9k's Avatar
Would it be safe to cut out a portion of the backing to the front grille? So that you would just be left with the diamond pattern which can be seen through. Or would this cause issues with debris? The purpose in this would to make my AEM CAI more visible.
Old Feb 1, 2010 | 05:26 PM
Alucard's Avatar
RX8 Club OG
if you are in the us, you will see your reinforcement bar if you do that... not a pretty sight
Old Feb 2, 2010 | 12:16 PM
kersh4w's Avatar
Hit & Run Magnet
paint the bar black.
Old Feb 2, 2010 | 02:42 PM
Rotr8's Avatar
whines all the way home
OPs reason for removal would be futil due to both post, you would not see anymore of it than you do now.
Old Feb 2, 2010 | 02:54 PM
blamerobb's Avatar
Use a dremil drill and ur good to go but I'm sure it'll be a pain on tha ****
Old Feb 2, 2010 | 03:25 PM
After doing this a couple of different ways I found the easiest way was to use a grinding wheel and lots of water for cooling...and just grind the 1/8" or so off the back in the areas that the holes are plugged.
Using a Dremel or such and doing them a square at a time is very tedious and doesn't look too good at the end
Old Feb 9, 2010 | 03:13 PM
tflorko's Avatar
have some pics? ps...where can I get a custom grille for my 2010 rx8?
Old Feb 9, 2010 | 03:23 PM
I just drilled out the diamonds with bit (found a bit that fit perfect but obviously the holes are round). I did two rows to open up for my oil cooler.
Old Feb 9, 2010 | 03:37 PM
Cut the grill completely out of the open lower half, leaving just the border and upper part. I used a jig saw to do this when I ran the Racing Beat ram duct. All you'll see doing your suggestion will be the bar
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
