Help! - Failed state inspection
Old Jan 29, 2010 | 04:38 PM
RotaryZZ's Avatar
Question Help! - Failed state inspection
I've brought my '04 (only 35k miles) in for the NJ state inspection few days ago and find out it has failed the emission tests. Specifically, part of the inspection report reads like this
OBD/Emission: FAIL
OBD System - Readiness Status:
Catalytic Converters: NOT READY
Heated Catalytic Converters: UNUSED
Oxygen Sensors: READY
Oxygen Sensors - Heaters: READY
EGR Systems: UNUSED
Secondary Air Injection: NOT READY
Evaporative System: NOT READY
Fuel System: READY
Engine Misfire: READY
A/C Refrigerant: UNUSED
Comprehensive Component: READY
Overall Readiness Result: FAIL
Overall OBD System Result: FAIL
And the inspector has highlighted all those that shows "NOT READY" and "FAIL" and told me those needed to be fixed up in 45 days.
Anyone here has any clue as to what may have been wrong or broken?? I hope its not the cat since it would be one expensive repair!!
Old Jan 29, 2010 | 04:40 PM
Jon316G's Avatar
Grasshopper
Did you replace or disconnect the battery before going?
random question but are you sure you have a catalytic converter on your car? (not sure if you're the original owner)
if so, maybe it's broken?
Old Jan 29, 2010 | 11:03 PM
RotaryZZ's Avatar
I think the problem has more to do with mechanical rather than just electronics, so clearing the "codes" - which I don't have - won't really help the problem I believe.
I am the original owner so I know it has the cat in there.
That's what I am worrying about. I have the impression that the cat will last much longer than 35k miles. But anyway what could have possibly caused its premature failure?! I always use unleaded fuel and I have never done any modifications on the exhaust/intake system either. Regardless, I believe Mazda will cover the cat under a 8 yr/90k+ miles warranty in case the cat is really broken.
Old Jan 30, 2010 | 04:12 AM
Jon316G's Avatar
Grasshopper
What... that is no where close to what I was getting at...
If you disconnected the battery before going, you'll receive "not ready" failures because the car requires a few drive cycles to generate data the emission people need to gather.
Old Jan 30, 2010 | 12:25 PM
RotaryZZ's Avatar
ic. Anyway, it's too late now. I need to show them with repair receipts and reords and go thru the emission tests again.
So anyway, what possibly seems to be the problems for the emission system on my car? Do you think there is really some problem with the cat
Old Jan 30, 2010 | 12:42 PM
ilovemy8's Avatar
dude go to another place after a couple days. or find some one in yur area that can get yu one with out all the hassle..
Old Jan 30, 2010 | 03:57 PM
LGukas's Avatar
You don't have to show them the receipts... You can repair by yourself. If you know what is wrong with Your car...
Old Jan 30, 2010 | 04:12 PM
shaunv74's Avatar
Power!!
Do you have a CEL? If there is a problem with the cat. or the cat sensor it should throw a CEL. causing you to fail the test.
If you don't have a CEL then you probably need to put 3-4 cold start to full warm up drive cycles on the car.
If you do have a CEL bring the car to autozone and have them read the code. Chances are you have a bad cat. sensor and it needs to be replaced. Otherwise the cat. itself may be bad. The dealer can check as well. You have a 6yr 80K emissions warranty if you have a bad cat. so it should be replaced under warranty.
I had a bad sensor that caused me to fail once I replaced it I passed with no problems.
Otherwise it is common for the cat. to fail but it should significantly degrade your performance so you'd notice it.
Old Jan 30, 2010 | 04:25 PM
expo1's Avatar
He's as bad as Can
In the Peoples Republic of New Jersey doing this is not that easy, he should have tried a private shop first. Since he went through a state inspection station first a record of his failing is on file with the state. To quote from another car I had inspected.
" THE RESULTS OF THIS INSPECTION HAVE BEEN TRANSMITTED TO MVS "
Private shops spend a large amount of money to be connected to the MVS system and to acquire the state approved equipment to preform inspections. One needs to have a really good relationship with the private shop in order to get them to overlook a legit problem and pass a car. At this time the OP also has a red failure sticker in his windshield so he will have issue were he to pass a roadside inspection which does happen in this state. I do advise him to find out what is the issue with his car and post back here.
Old Jan 30, 2010 | 04:33 PM
expo1's Avatar
He's as bad as Can
That is not correct for NJ, From THIS LINK He will also need to fill out the attached form.
Emissions repairs
If your vehicle fails for emissions violations, you must have the repairs completed by a registered Emissions Repair Facility (ERF). For your convenience, you may find an ERF using our online search or by calling 1-888-NJ-MOTOR.
When you fail the inspection, you will get an Emissions Repair Form and a Vehicle Inspection Report that will help determine what caused the emissions problem. You can download the Emission Repair Form [pdf] if you did not receive it.
If your vehicle did not pass the enhanced emissions inspection, it is producing more pollutants than the standard for its model year - check if it is still under warranty and contact your manufacturer.
File Type: pdf
Old Jan 30, 2010 | 05:15 PM
Emissions repairs
wow ... I thought NYC suck at emission testing ... I guess NJ is far worst.
Old Jan 30, 2010 | 05:38 PM
LGukas's Avatar
wow ok I thought that the law is the same like in CT.
hmm what about this.. I don't have a CEL and I have a problem with cat. (the dealer gonna replace the cat under warranty)
Old Jan 30, 2010 | 07:17 PM
shaunv74's Avatar
Power!!
Yup. That is also possible. But if you have a problem with your cat. and you don't have a CEL it would not show up as failing the OBDII emissions test. If you don't have a CEL your car doesn't know there is a problem with your cat. there is plenty of documentation of people melting cats without throwing CELs. But that's not why he failed the test.
Old Jan 30, 2010 | 11:04 PM
RotaryZZ's Avatar
NJ
I don't have the CEL on and yet the inspection indicated it is a OBD/Emission failure.
Btw, is NJ having an enhanced emission test now?? Oh well, I am gonna take it to the dealer to check that out and just hope it is still under warranty.
Speaking of dealers in NJ, which one is more capable and honest? I've heard a number of good reviews about Wayne Mazda, but those remarks are quite some time ago already. The closest to mine is Open Road in Morristown which they just opened for business recently. Guess they're the same business group as the Open Road Mazda in Edison.
Old Jan 31, 2010 | 07:23 AM
invasion08's Avatar
Wayne Mazda and when you call to make an apppointment tell them you want Kevin to check out your car
Old Jan 31, 2010 | 03:06 PM
RotaryZZ's Avatar
NJ
Any one of service rep at Wayne Mazda you would recommend and that I should ask to talk to?
Old Jan 31, 2010 | 03:21 PM
Wayne Mazda is a good place. If Kevin still works there that will be even better(we havent heard from him for a while after his FD caught on fire and he is getting married)
Give Wayne Mazda a call and ask
Old Feb 1, 2010 | 08:54 AM
RotaryZZ's Avatar
NJ
But Kevin is the technician only not the service rep right?
Old Feb 1, 2010 | 09:13 AM
Vlaze's Avatar
The Angry Wheelchair
Just wanted to chime in, but CT inspections are a joke. If you pass emissions, you pass inspection technically speaking. There is no safety inspection required.
In NY this would not fly, you have to have a safety inspection. In other words your brakes, lights, so forth can be absolute ****, and you still pass.
Not sure how many other states are like this.
gwailo
May 14, 2024 06:57 AM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Forevermore
Sep 20, 2015 01:04 PM
TJSiegrist
Sep 10, 2015 09:29 AM
