What Shocks Should I Get?
Old Jan 23, 2010 | 10:21 PM
klanham08's Avatar
Blackin' Out The 8
SORRY I MEANT SPRINGS, NOT SHOCKS!!!
I have been debating on whether to get aftermarket springs or not. However, my 8 is my daily driver so I do not want to get springs with a big drop.
What brand/type of springs are out there that can give me better performance and a bit of a drop without being too low?
Old Jan 23, 2010 | 10:24 PM
The Reverend's Avatar
That's a lie
Shocks should not affect ride height. To change your ride height you want springs.
That said, Koni Yellows do seem to drop a tad lower than say Tokico Dspecs.
Old Jan 23, 2010 | 10:26 PM
klanham08's Avatar
Blackin' Out The 8
Ahhh that is what I meant....SPRINGS! I need I would do something like that lol.
So would you recommend Tokico Dspecs?
Old Jan 23, 2010 | 10:27 PM
That's a lie
Lol I am sorry Koni and Dspecs are both shocks not springs I was still assuming you meant shocks.
Racing Beat and Tein H tech are two springs that will not drop your car that much
Old Jan 23, 2010 | 10:28 PM
klanham08's Avatar
Blackin' Out The 8
Lol my bad....work is kicking my *** this week so I am exhausted!
But I just noticed the Racing Beat springs, but I haven't started looking at Tein's yet, but I have heard good things about Tein.
Old Jan 23, 2010 | 10:31 PM
That's a lie
Here are a couple of threads on springs you should check out:
https://www.rx8club.com/showthread.p...wering+springs
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/spring-rates-other-basic-suspension-info-79096/
Old Jan 23, 2010 | 10:32 PM
Racing Beat all the way.
When change springs change shocks at the same time.
Old Jan 23, 2010 | 10:40 PM
klanham08's Avatar
Blackin' Out The 8
Ok, here is my next question:
What is the difference between Shocks + Springs compared to Coilovers?
(I apologize now if this is a n00b question)
Old Jan 23, 2010 | 10:54 PM
You don't need coil overs unless your going to track it.
Coil overs have the spring included.
Old Jan 23, 2010 | 11:09 PM
klanham08's Avatar
Blackin' Out The 8
Ok that is what I figured. Plus I don't have $1,000+ to dish out for them.
Old Jan 24, 2010 | 11:00 AM
StrokerAce's Avatar
If you don't want to lower it, stay on the cheap, consider a set of sway bars instead of springs.
Old Jan 24, 2010 | 11:14 AM
klanham08's Avatar
Blackin' Out The 8
What brand of sway bars can you recommend?
Old Jan 24, 2010 | 11:31 AM
NgoRX8's Avatar
sways would do much more performance wise than a set of springs.
Any brand will work. I personally have Progress which offer the most roll stiffness and are adjustable, but I've ridden in cars with Tanabe Sways and Racing Beat Sways. Can't go wrong with any of them.
Old Jan 24, 2010 | 11:48 AM
TopGear8's Avatar
mkuhnracing.com
Also, its not good to get just springs, and not aftermarket shocks because the stiffer spring rates of aftermarket springs will wear down your OEM shocks faster since they were not valved to handle stiffer springs.
Old Jan 24, 2010 | 11:54 AM
klanham08's Avatar
Blackin' Out The 8
So what is the difference between getting Coilovers and getting Shocks + Springs?
Old Jan 24, 2010 | 11:59 AM
NgoRX8's Avatar
usually height and dampening adjustability. except tein basics which only adjust height.
aftermarket shocks for the 8 allow dampening adjustability but height is dependent on the spring.
Old Jan 24, 2010 | 12:54 PM
tmak26b's Avatar
You will most likely blow your stock shocks out if you change springs only
Old Jan 24, 2010 | 09:35 PM
klanham08's Avatar
Blackin' Out The 8
So is there a price difference between getting new Shocks + Springs and getting new Coilovers?
Old Jan 24, 2010 | 11:23 PM
StrokerAce's Avatar
Koni's ~$700+springs ~$200 Total $900
Coilovers $900-$4500
Old Jan 25, 2010 | 06:09 AM
klanham08's Avatar
Blackin' Out The 8
I see lol. And would it be ideal to get the same brand of Shocks and Springs or does it really matter?
Old Jan 25, 2010 | 11:03 AM
StrokerAce's Avatar
Should not matter. The shock mfgr's for the most part don't make or even supply springs except for their coil over kits.
Old Jan 25, 2010 | 11:08 AM
klanham08's Avatar
Blackin' Out The 8
Alright thanks everyone for your help
Nisaja
15
Nov 21, 2015 10:30 PM
duworm
Oct 1, 2015 04:57 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Paul_Y
Sep 21, 2015 02:23 PM
FoxRacer600RR
Aug 31, 2015 06:32 AM
