Royal Purple BADDD???!!! PLEASE HELP!!!
Old Jan 15, 2010 | 03:39 PM
ChillinRard's Avatar
ChillinRoD
THE mazda delarship said that i should never run SYNTHETIC OIL LET ALONE ROYAL PURPLE IN MY Rx8...but i ALREADY HAVE SINCE NOVEMBER!!! WHAT SHOULD I DO??? I know i cant change back to regular oil but what effects would 5w-20 royal puple would have on my 8??? I seached the fourms and couldnt find a direct answer please help! What Should I Do?
Old Jan 15, 2010 | 03:42 PM
oh god, not another synthetic oil thread.
nothing wrong with royal purple synthetic motor oil, you can continue to use it without worry. Many people here run that.
not sure what you searched but here's the short answer.
- you're fine with it
- you CAN switch back
- as to what "effects" it has: it does its job as an engine oil at least (if not better) then conventional oil.
Old Jan 15, 2010 | 03:44 PM
The Reverend's Avatar
That's a lie
troll
Old Jan 15, 2010 | 04:06 PM
plain ole wanker's Avatar
wankel my wanker
Can you tell me what this means "Taking It All In Like A Dried Up Sponge" or maybe you can use this to remove the RP
http://www.royalpurple.com/faqs-rotary.html
Old Jan 15, 2010 | 04:11 PM
mike[piston eater]'s Avatar
O' Let's do it.
newb
Old Jan 15, 2010 | 04:13 PM
ndhoffma's Avatar
OMGZ!!!! UR ENGINE IS RUINED!!!!!
Search... you should actually be using synthetic 20w-9000000
Old Jan 15, 2010 | 04:21 PM
tubingchamp's Avatar
What mawd bug?
Dealerships are mostly idiots.
Old Jan 15, 2010 | 05:06 PM
kersh4w's Avatar
Hit & Run Magnet
+1
yep
bse50's Avatar
#50
A simple search would have solved this
Old Jan 15, 2010 | 06:21 PM
cidvicious831's Avatar
Old Jan 15, 2010 | 07:14 PM
Cf05's Avatar
Not Faster Thn Ryans Spd3
man don't tell us you searched and lie there are probably more threads on this topic than any other!
Old Jan 15, 2010 | 08:31 PM
b'Eight''s Avatar
I've run Royal Purple in my car since the first oil change. I have 40K miles. Never had a problem. I may switch to Castrol Synth since RP is becoming cost prohibitive for me.
Old Jan 19, 2010 | 10:19 PM
ChillinRoD
thats all interesting, i didnt have much time to do all the searching required to find which thread talked about royal purp in itself and what itll do to my 8, i had milky looking stuff in my oil so i thought it was caused by the synthetic oil but after further research its water that somehow got in my oil, so i will do another oil change, and yes i will accept your harsh criticism bkuz i am a newb, i jus signed up for this forum and i am new to forums and rotary engines and for the most part owning a car, this is my second car after owning a ricer eclipse so im just tring to learn as much as i can from u guys, im sorry for the time u wasted on reading and replying to my post, and those of you who has replied helpfully thanks
Old Jan 19, 2010 | 10:25 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
Don't change the oil every time you see the milky stuff. It's water from condensation. =normal.
Old Jan 19, 2010 | 10:37 PM
Pico's Avatar
It's Complicated
Use it you'll be fine
Now if you ask us what weight you should use well then put on your flame suit cuz your going to get burnt.
Search it out (thou there is no real answer to this question)
Old Jan 19, 2010 | 10:42 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
You searched - don't you feel better now?
Old Jan 20, 2010 | 01:54 PM
ChillinRoD
lol nahh i already searched its 5W20
Old Jan 20, 2010 | 01:55 PM
ChillinRoD
thanks, i was wondering if that was common
Old Jan 20, 2010 | 01:59 PM
bse50's Avatar
#50
My user manual says 5w30 so...
The real answer is that it mostly depends on your use of the car
Old Jan 20, 2010 | 03:10 PM
jmc23200's Avatar
Apparently you don't know how to search. Correct me if I am wrong, but searching 5w20 will most likely pull up more threads saying not to use 5w20 then threads saying to do so. Now the manual says 5w20. 5w20 is recommended only in the U.S. Coincidence? I think not.
Old Jan 21, 2010 | 01:54 PM
ChillinRoD
Wow that comment really help out alot? No it didnt. If your comment isnt going to be productive or gain me more knowledge on what im doing maybe u should just shut up
Old Jan 21, 2010 | 01:56 PM
hakuna matata!
Wow.
Die.
ChillinRoD
obviously if u search enuf youll find that its undecided what wight to use therefore it falls into the preference category, i choose to go with the car Manuel and all those who said use 5w-30 in this instance
Old Jan 21, 2010 | 02:00 PM
ChillinRoD
i said 5w-20 but i meant 30 btw
Old Jan 21, 2010 | 02:11 PM
jmc23200's Avatar
5w20/30 is what the dealer will tell you you need to use. After many blown rotary engines, tear downs and rebuilds, some of the very knowledgeable members on this board will never use a 5w20 or 5w30 oil and swear by heavier oils like 0w40, 10w40, 10w50 and even 20w50(NYC's fav) followed with premixing or the sohn adapter.
Bottom line, it is your car, do what you want. Seeing that everyone who follows the manual's "recommendations" gets rewarded with blown engines, I will be using a heavier oil.
