Mazdaspeed splitter, DIY?
Old Jan 11, 2010 | 06:03 PM
Z0oMzo0m's Avatar
Looking for someone who has seen or has done an extra splitter for the mazdaspeed bumper.
I have seen it here before and ive spent hours searching for it again! and have had no luck. I have the link for the stock bumper to make a splitter.
Basically looks somthing like the rolex rx8 have
Old Jan 17, 2010 | 07:54 PM
@!!narotordo's Avatar
FLAME ON!
Dude I seen this before. About two weeks ago I found some guy on ebay that was selling some for $98. They looked like dry carbon. So I emailed him asking if they are still for sale and to send me some pix. He said to paypal him but about three days later I went to check his ebay site and he took it down. Shady. So I tryed looking on google. But cant find anything.
Old Jan 17, 2010 | 08:35 PM
FLAME ON!
Here ya go I found this one https://www.rx8club.com/showthread.php?p=3241463
Old Jan 18, 2010 | 04:08 AM
kersh4w's Avatar
Hit & Run Magnet
go to the source...
http://www.carbon-creations.com/shop...cat=RX-8+04-08
Old Jan 18, 2010 | 05:42 AM
tiltmode43's Avatar
OMGITM!
Origin sells a similar piece, sides as well!
www.tougefactory.com
Old Jan 18, 2010 | 06:46 AM
EricMeyer's Avatar
Template: http://gallery.me.com/meyermotorspor...&bgcolor=black
First pass: http://gallery.me.com/meyermotorspor...&bgcolor=black
Reinforced front mounting location. Our 140 lb mechanic (lil' e) can stand on the front of the final solution: http://gallery.me.com/meyermotorspor...&bgcolor=black
Find an ABS plastic sheet at your local plastics distributor. I think I got a 4' x 8' 3/8" for under $100. Cut it with a jigsaw. Mounting will be your issue. Have yet to drive the car/test it. Most likely a really big splitter will require some help with the rear end as you'll be producing a high amount of high speed front grip on the track. Keep in mind that for a big splitter a car normally has a rear wing to balance the car out. Also keep in mind that a lowered car now has a nice protruding crash target for curbs and cement parking blocks. Lastly, the splitter will only work in high speed cornering situations. The consensus is 100 mph and above but I disagree. We are planning to test with and without the splitter (and wing) to validate this. Will have data later this summer. I'm expecting even better braking from high speeds (like entering the braking zone into 10a at Road Atl). Should make grip for T1, the esses, T5 and 12.
Old Jan 18, 2010 | 05:41 PM
Z0oMzo0m's Avatar
Thank you Eric!! this was it!
Thanks everyone for the help!
Old Jan 18, 2010 | 05:51 PM
Z0oMzo0m's Avatar
I dont track the car, but i kinda like the look of the splitter up front. I dont think i would go the size that you installed, but it looks good.
How does it fit in the center? with the MS nose having the lip on the sides as it sits. Is there a gap between the the peices?
Old Jan 19, 2010 | 05:13 AM
EricMeyer's Avatar
IN
A little gap. Filled it with a bead of caulking. If your going for the cosmetic look think then I would be hesitant about running this-----especially if your car is low. We have to take the nose off the car (which is a feature we built into this nose/splitter) to get the car in our race car hauler. I think you'd find times during daily driving where your likely to hit things by accident and tear off/hurt both the splitter and the nose.
E
Old Jan 19, 2010 | 02:55 PM
Z0oMzo0m's Avatar
yeah thats true, i not really that low, i have only bottomed the front bumper once in orlando, but was my fault. just put a few scratches under bumper.
But thanks for your opinion on a negative side for a daily driver.
Old Jan 19, 2010 | 04:26 PM
c0ldf1ame's Avatar
a racer friend told me once splitters are pretty much meant to be knocked off. you have to consider that even if your not sitting very low, its still sticking out 3-4 inches farther than your bumpers lowest and most forward point. Remember to use fasteners that can break away relatively easy so if you do end up hitting it on something, it wont take out your whole bumper with it, just incase.
Old Apr 8, 2010 | 04:47 PM
Highway8's Avatar
Registered RX8 Nut
Was that 3/8" or 1/4" thick abs? I called around and everyone sells the 1/4 4'X8' for around $100 but a 3/8" sheet is 3-4 times as much.
Wondered how the testing on this went? I track my car 4-5 times a year and was thinking about making and installing a similar splitter for track use only. I have the whole MS body kit with rear bumper and spoiler. I find the front end of my car gets a little lite on the 80-90+ mph turns. Thought this might help.
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
mitchrx8
Sep 13, 2015 08:05 AM
yankeepicker
Sep 11, 2015 05:42 PM
