Metra Problem?
Old Jan 10, 2010 | 10:17 PM
amccart33's Avatar
Question Metra Problem?
I installed a double din radio with the metra and everything is working right but when i was connecting wires into the metra box the stock lcd screen wire harness does not fit! The harness is to big for some reason..everything else fits fine but i'm not sure what i should do..so for right now i'm driving without the lcd and its really starting to bug me! help?
Old Jan 10, 2010 | 10:29 PM
Foxxman's Avatar
..not that this will help, but what system you installing? I'm possibly looking at installing a double din, but unsure of what head unit to put in.
Old Jan 11, 2010 | 12:18 AM
amccart33's Avatar
Pioneer avhp3100dvd i absolutely love it
Old Jan 12, 2010 | 07:19 AM
RX8Geek's Avatar
Missing Cable
Hey - you need to pull an adaptor cable off of the OE radio. Look at the side of your OE radio (driver's side). If there is a cable attached to the radio, remove it and use it to connect the display to the kit.
Old Jan 12, 2010 | 02:23 PM
chad79's Avatar
I'm about to do the same install here in a few weeks. Let us know what the fix was! Thanks!
Old Jan 12, 2010 | 03:28 PM
amccart33's Avatar
Thanks, I'm gonna try that shortly and i'll let you know how that goes
EDIT: Took your advice today and everything worked out. Thanks A lot!
Digitz0070
55
Jul 25, 2017 08:40 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Learners_Permit
Sep 27, 2015 07:38 PM
