Where to find rear exhaust spring w/ bolt?
Old Jan 10, 2010 | 10:13 PM
figit's Avatar
I've lost one of the 2 spring loaded bolts for the rear pipe and cant seem to find them online anywhere.
A search pulled up the replacement bolt via this thread: https://www.rx8club.com/showthread.p...ht=spring+bolt
But I need the spring as well. Any suggestions would be greatly appreciated.
Thanks,
-m
Old Jan 10, 2010 | 10:25 PM
the dealer unless someone has one lying around
Part # YJ15-40-582 , about $6 msrp
the bolt/stud is Part # B31R-40-584, about $12 msrp from the dealer
the nut that holds the bolt/stud to the flange is Part # 9991-61-000
the nut that tightens the spring to the flange is Part # 9994-01-003
Old Jan 10, 2010 | 11:08 PM
figit's Avatar
U rock, thanks man. I was hoping to find something online but the dealership isn't far, thanks again!
-m
Old Jan 11, 2010 | 08:55 AM
kamichael25's Avatar
Marine01
I used this website... Great prices and easy to figure out shows pictures as well...
http://mazda-parts.com/
http://www.mazda-parts.com/partscat.html
Happy hunting...
Old Jan 11, 2010 | 12:51 PM
nuke0907's Avatar
Never Blend In
-m
you can also try going to a dealer and ask if there are any RX8's getting their Cat replaced. they use all new hardware so just ask if you can have the old ones. i did this and they gave them to me for free. just a suggestion.
Old Jan 12, 2010 | 09:46 AM
~ Kuro ~'s Avatar
This place might have it too:
http://www.trademotion.com/partlocat...&siteid=214264
didn't have time to look, but....
Old Nov 7, 2015 | 12:56 PM
Jaaaaack's Avatar
OEM part measurements
Since this is still the first google result for "rx8 exhaust spring bolt" I figure it's worth bumping with this info:
I bought the Mazda OEM exhaust springs and studs with part numbers: YJ15-40-582A and B31R-40-584 respectively.
The stud is threaded M10-1.25 on both sides.
More interesting is the hex nut size on the stud.
13mm socket will fit it, but there is a lot of slop possibly because of the curved corners on the hex.
A 1/2 inch, deep socket, is a far superior fit (see picture).
Anyway, hope this helps somebody not pay ~$45 for the OEM parts like I did.
I will edit this post when I do the install later on this week with any problems I run into.
EDIT: Keeping with my promise: the installation went reasonably well. I used a Magnaflow 23909 for my new cat/silencer setup.
It's worth noting that the shorter threaded side of the spring bolt is intended to screw into the cat/silencer pipe. The 23909 is not threaded in these holes and the flange is thick enough that only ~2 threads end up protruding on the other side of the flange hole. I simply turned the bolt around and used the longer threaded side to secure it to the flange. Problem solved.
Attached Thumbnails Where to find rear exhaust spring w/ bolt?-img_2159.jpg   Where to find rear exhaust spring w/ bolt?-img_2160.jpg   Where to find rear exhaust spring w/ bolt?-img_2161.jpg   Where to find rear exhaust spring w/ bolt?-img_2162.jpg
Old Nov 7, 2015 | 01:14 PM
Autozone sells the stud and spring that works in the DIY section for a few bucks.
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
mitchrx8
Sep 13, 2015 08:05 AM
WingleBeast
Sep 9, 2015 10:10 AM
