Advice needed
Old Jan 5, 2010 | 12:11 PM
fun factory's Avatar
Advice needed
Hi guys,
Currently driving a pre fl 6mt. Car engine dies off when im in neutral or clutch in for about or more than 2 secs when travelling at speeds above 30km/h. Example would be coming to a rolling stop at about 30km/h, rpm just drops to zero and engine dies off. Any advice would be appreciated. Thanks
Old Jan 5, 2010 | 12:20 PM
Solidtrance's Avatar
Pull the battery for ten seconds. Then do the 20 brake stomp e-shaft reset procedure. Not sure what your problem is, but these two steps couldn't hurt and may fix her right up for you.
If that doesn't work....sacrifice a live chicken over the hood.*
*Note: This should only be done by a trained professional.
bbostic5
Feb 24, 2019 05:32 PM
dbarber
Jul 25, 2015 01:34 PM
thedragonrotar
Jul 22, 2015 08:46 PM
Belalnabi
Jul 17, 2015 07:48 PM
