West RX-8 Forum Serving CA, NV, AZ, HI
whats wrong wit my 8? :\
Old Jan 2, 2010 | 09:13 PM
Project_8's Avatar
I've had my 8 for about 2 yrs already. An o4' that is. There was something that's been buggin me. I hardly drive my car. Every sat and Sunday I would always have to jump start it. The battery fails or the alternator. On top of that my check engine light recently went on. Could it be my ignition coils? Exhaust? Cat? Btw... haven't done oil change for a long time and I have a python alarm wit scanners that drains my battery. -__- help!?!
Old Jan 2, 2010 | 09:27 PM
myriadshalaks's Avatar
rot8ing
lol
Old Jan 2, 2010 | 10:09 PM
CruelNewb's Avatar
Battery test, alternator test. Have the shop or dealer check for "draws". Most likely your battery is old but it could be faulty wiring in your alarm system.
Old Jan 3, 2010 | 03:03 AM
AJ's Shinka's Avatar
Enthusiast
Take your car down to Autozone to check battery, alternator, and check your codes then clear them. Get rid of/or fix your alarm that drains your charge. Change your oil, coils and spark plugs while your at it. Then get back to us.
Old Jan 3, 2010 | 03:21 AM
xl2oGel2x's Avatar
Ninja Name: Shimojikushi
indeed it seems what this car needs is some of its maintenance done
Old Jan 3, 2010 | 01:05 PM
Project_8's Avatar
The weird part is, I had this issue with the car for a while where I have to jump start it. Its jus that I never had the check engine light go on until now. I already flushed my fluids and is planning to do an oil change today. When I jus got the alarm installed, my car never died like that. Had the alarm for like 2-3 yrs and it jus started actin retard this past few months. Thanks AJ and CruelNewb. I'll go ahead and do that to see wats up.
Old Jan 3, 2010 | 01:07 PM
Project_8's Avatar
Oh and I also recently did change and upgrade the spark plugs and spark plug wires. Had JRX Rotary do that for me.
Old Jan 3, 2010 | 05:59 PM
nikkdizzle's Avatar
Daddy's Home...
how does it run now?
Old Jan 3, 2010 | 11:45 PM
To be named later's Avatar
Now with 25% more fluff..
So.............your alarm is two to three years old, and it drains power from your battery.
Let me guess............your battery is at least 2-3 years old as well and nearing its expected usefull life expectancy?
Old Jan 4, 2010 | 03:25 AM
Enthusiast
Find out what that check engine light code is all about...maybe wires aren't on the right way or loose maybe or could be something else entirely. OBDII scanner or Cobb accesport will read it so you know exactly what you're dealing with. Or like I said autozone will check it for free. It is a better tool to tell you whats wrong than us troubleshooting/guessing from the computer. There is a long list of codes on here that will translate the check engine light it for you.
Old Jan 5, 2010 | 01:53 AM
Project_8's Avatar
LOL... yes my battery is very old. im plannin on upgrading to optima, yellow cap. oil change and top off my coolant did nothing. still has the light on. maybe i shud drop by autozone this sunday to see whats up. thanks AJ. :D
Old Jan 5, 2010 | 03:55 AM
@!!narotordo's Avatar
FLAME ON!
Originally Posted by myriadshalaks
lol
Best post so far
Old Jan 5, 2010 | 04:07 AM
volcomx31's Avatar
Silver Power
Old Jan 9, 2010 | 04:18 PM
Project_8's Avatar
LMFAO! Well found out the prob, my throttle ain't opening.... -__- fml
Old Jan 10, 2010 | 03:47 AM
MaRxtin's Avatar
are you a recent owner of a rx-8?
Old Jan 10, 2010 | 04:04 AM
Buddy Jesus's Avatar
Cruisin' down the street
Wut?
Old Feb 19, 2010 | 04:48 PM
Project_8's Avatar
So Sorry fellas! been bz with chinese new years n trying to fix the throttle. I cleaned it recently but light came on again. Heard the cause can be cuz i didnt clean my REVi intake properly. I had my 8 since 2oo5 til present.
Old Feb 19, 2010 | 04:54 PM
Project_8's Avatar
Correction since 2oo6
Old Feb 19, 2010 | 05:16 PM
ChesteRx8's Avatar
how much mileage is in ur car?
Old Feb 19, 2010 | 08:08 PM
Project_8's Avatar
Have about 60 k
Old Feb 22, 2010 | 07:27 PM
Project_8's Avatar
So i found out it was P0661. Intake manifold. :/
Old Feb 22, 2010 | 08:45 PM
Kingsfan's Avatar
PS - ducks suck
danger?
Old Feb 22, 2010 | 10:33 PM
Project_8's Avatar
if i dont take care of it... Its possible my engine will blow.....
Old Mar 1, 2010 | 10:39 AM
Faria's Avatar
LikeThunda
i duno about your throttle... but i heard alot of 04 Rx8's had recalls...about battery problems and faulty Starters...and they Needed an New Flash...etc... supposedly there wasnt enough power getting to the starter,,or the starters couldnt handle it...i duno....Check the dealer for Recalls.. 04 had alot...
Old Jun 16, 2010 | 05:44 PM
Project_8's Avatar
alwaysrunning, i had Mazda take my 8 all the recalls already. found out more things about my car. well i lost my battery cover and i have a cf hood, therefore water is getting onto my battery causing corrosion. to top it off my ignition coils are really bad. plus what i mentioned earlier about the throttle not opening fully. sadly Im broke as of now to get things fixed. i recently placed an order from BHR for coil system so that's gonna take a month or so. then imma get hold of Optima yellow top D35 to replace battery. hope that fixes things up a bit more. the throttle prob.... did some research shudnt be a big issue. jus have a lag in pushing my car on track or lost of power. idk
LB2739
Jul 9, 2019 02:25 AM
WranglerFan
Nov 5, 2017 09:35 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Learners_Permit
Sep 27, 2015 07:38 PM
chadsta
Sep 20, 2015 11:00 PM
