Wheel Refinishing??
Old Dec 29, 2009 | 03:07 PM
MazdaEight's Avatar
Wheel Refinishing??
Does anyone know a DIY method of refinishing wheels? Here are some pics of one of my wheels. All of the other wheels lips are like the dull part in these pics. Could I just polish all of the lips? What would I use?
Attached Thumbnails Wheel Refinishing??-1229091554.jpg   Wheel Refinishing??-1229091554a.jpg
Old Dec 29, 2009 | 03:56 PM
epikeddie's Avatar
That looks like surface rust to me.
You might be able to polish it out, but I think wetsanding is more in order to get that type of deposit off.
Old Dec 29, 2009 | 04:15 PM
Huey52's Avatar
Registered Zoom Zoomer
Try Mother's Mag & Aluminum polish. Works well for me with their Powerball.
http://www.mothers.com/02_products/05100-05101_b.html
http://www.mothers.com/02_products/05141.html
Old Dec 29, 2009 | 04:27 PM
Pico's Avatar
It's Complicated
Use this stuff it beats all others hands down.
http://www.75chromeshop.com/index.ph...oducts_id=2702
Good Luck.
Old Dec 29, 2009 | 04:46 PM
kersh4w's Avatar
Hit & Run Magnet
you guys dont think thats clearcoat coming off?
Old Dec 29, 2009 | 04:56 PM
and1kidd's Avatar
hmm does look like the clear coat to me.
Old Dec 29, 2009 | 07:57 PM
MazdaEight's Avatar
Well, thanks for the suggestions guys. I think I will try wet sanding them, then giving
em a good polishing.
Old Dec 29, 2009 | 08:38 PM
Pico's Avatar
It's Complicated
Second looks tells me that it could very well be the clear. Pics can be deceiving
Old Dec 29, 2009 | 08:55 PM
MazdaEight's Avatar
Soooo....I shouldn't sand them?
Old Dec 29, 2009 | 09:34 PM
Pico's Avatar
It's Complicated
First i would do some research into the finish on the wheel. Call manufacture
Before sanding/or compounding I would try the product that I mentioned
If there isn't a clear coat then the product I mentioned should take that out no problem.
Old Dec 29, 2009 | 09:44 PM
MazdaEight's Avatar
Alright. If it is just a polisher though, it probally won't work. I can run my fingernail
across it and have it catch where the dull starts.
Old Dec 30, 2009 | 07:30 AM
Huey52's Avatar
Always go from a mild to more aggressive approach, therefore start with mild polish and only progress with a cutting compound or wet sanding (in that order) if necessary. You'll be amazed at what simple mild polishing can often do.
Old Jan 1, 2010 | 07:43 PM
Pico's Avatar
It's Complicated
^ +1
Work smarter not harder
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
xAgyex
Sep 28, 2015 08:54 AM
