ok to use? (couple of suspension questions)
Old Dec 23, 2009 | 08:18 AM
Bigbacon's Avatar
2006 WB AT
So, thanks to some great people I was able to get some after market parts for my car and curious if I can use them with what I have or if I would just be best to wait till I can get the rest of the stuff I want (which may be a while)
I have a set of MS springs and PT sways sitting in my garage.
Least the sways, I know I can't use the stiff settings with my OEM end links. I suspect they will die a horrible death. Is it ok to use the OEM end links on the softest settings with these?
Same for the springs, I have what ever a 06 GT comes with. I know using them will mean less life on the OEM shocks but by how much? Are we talking they will die in a few months or like maybe a year or so less than they normally would?
I know people say don't do the springs by themeselves, get shocks and do them at the same time but I am ok with 2 different installs only because I have never done either one and would rather mess around now and have to take everything apart again down the road. I'm totally fine with this.
Old Dec 23, 2009 | 10:00 AM
justjim's Avatar
justjim
I have the PT sways with the OEM endlinks and I use them on medium stiff in the front and full stiff in the rear at track days and full soft front and rear for daily driving. So far so good 1 year and 5 track days out.
Old Dec 23, 2009 | 10:28 AM
elysium19's Avatar
The OEM links are strong enough, but they are still a pain in the *** with the hex key mechanism
Old Dec 28, 2009 | 07:39 AM
Bigbacon's Avatar
2006 WB AT
PITA is fine
I won't be adjusting the sway bars that much. I could be wrong though
Old Jan 4, 2010 | 09:26 AM
Bigbacon's Avatar
2006 WB AT
need to bring this back up because I am going to do the installs this weekend. Will I be ok if I install the MS springs on the OEM shocks that are on an Auto GT?
Old Jan 4, 2010 | 09:38 AM
JinDesu's Avatar
went back to srsly broke
I was just researching up the MS springs because I wanted to get them. From what I gather, even though the 280/197 rate quoted by MS is inaccurate on the high side, it is still far too stiff for stock shocks (especially the rear). Most threads that I searched up discourage using MS springs on stock shocks, as the shocks would give up far too quickly.
Old Jan 4, 2010 | 10:02 AM
Bigbacon's Avatar
2006 WB AT
what is far to quickly mean though in terms of the life of the shock? My plan is to get new ones sometime this year.
I understand the rates that we have on the MS springs are way high (or at least seem to be) I've seen threads that rate them the same as stock ones or the high rates so if you place them some where in between aren't they fairly close to other spring sets that are said to be ok to use on stock shocks?
Old Jan 4, 2010 | 12:17 PM
JinDesu's Avatar
I personally would doubt the MS springs are near stock rating, since they are stated at 280/197 by MS themselves. It would be terrifying if there were such high discrepancies between their products.
I have no idea what "quicker" means in shock life, especially since stock shocks with stock springs are supposed to last a long time (I've heard numbers of 60k miles). It's not a linear digression of life when you're dealing with shocks and spring rates, though. I'm making educated guesses based on everything I've read, and I would not imagine your shocks dying in a year with the MS springs.
Old Jan 4, 2010 | 12:42 PM
Bigbacon's Avatar
2006 WB AT
the rates things is a mystery, the other rates I was going on was testing done by a member here that said the set they tested was not anywhere near the number we see which there is always some debate as if those are correct or not.
I really have no idea.
Old Jan 6, 2010 | 07:11 PM
Bigbacon's Avatar
2006 WB AT
I've read the DIYs I could find (wish the spring install had photos) for spring installs and sway installs. The sways seem pretty straight forward but the spring one looks a bit more complicated. Is there is anything I should know that isn't really covered in the DIYs? Is there anything I should look out for, like having to loosen or remove bolts that deal with alignment on either install?
I think for now I am going to put my sways on the middle stiffness in the front, not sure about the back. I am using stock end links so I don't want to kill them too much.
Going to be a busy weekend.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
