Help me!!! New clutch!!!!!!
Old Dec 15, 2009 | 02:43 PM
DK's Avatar
DK
Smile Help me!!! New clutch!!!!!!
i need to get a new clutch kit. i need to know what brand should i get and where. thank you please help
Old Dec 15, 2009 | 02:47 PM
is your clutch burnt up?
are you looking to upgrade or simply replace with OEM?
do you track your car?
It's impossible for us to tell you what you "need" without knowing what you want.
if youre looking for just an OEM replacement then go to www.onlinemazdaparts.com , look up your vehicle, and find the clutch. you can order directly from them
Old Dec 15, 2009 | 03:37 PM
Go here.
http://blackhaloracing.com/products-...tch--flywheel/
Old Dec 23, 2009 | 07:16 PM
epikeddie's Avatar
My turbo clutch....
Well I've been toying with the idea of going turbo for 2010. My Miata buddy recently ran into a brand new Ogura Racing Clutch which he was going to use on his Miata. A later look at the part numbers revealed that it was for the SE3P as well (our car).
This is the one I got: http://www.rhdjapan.com/home/products/product_image_popup.php?str_inventory_id=14205&str _product=ORC%20OGURA%20ORC309%20%20Single%20Metal% 20%20Clutch%20Kit%20Miata%20Roadster%20RX-8%20Standardℑ=
If I didn't pick up this kit for less than half of what it retails for, I would've went with the BHR flywheel / BHR-SPEC Clutch Kit (Stage 2+) because of my goals for the future. Why? It has the the torque capacity without the expense of weight or driveability - what more can you want?
The ORC is really overkill if you look at the system. The thing is really a race-inspired piece. The same friend that sold it to me eventually went with a more serious setup - Tilton 7.75" Multi-Plate Setup.
I can't wait to hear that clutch plate rattle every time I push in the clutch pedal!
Although....this won't go in until I finish the rest of my collecting for the turbo install.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
