Front jack point...clarification
Old Dec 8, 2009 | 02:35 AM
ClarityMD's Avatar
Ok, so for all RWD cars I've owned, the front crossmember is the location to jack the front end.
It's also on pg 29 general info on the FSM.
What is the guy in this thread talking about?
https://www.rx8club.com/series-i-tech-garage-22/oil-change-%3D-rough-idle-%3D-cracked-engine-mounts-117146/
"NEVER put a jack on the cross member.
It will distort and change your wheel alignment.
The ONLY jacking points on the '8 are on the frame rails and clearly marked.
Yeah, don't do that.
If you want a kick, try it and watch what happens. It isn't pretty.
The FSM always assumes you are going to hit the customer up for a wheel alignment after every service."
Pretty skeptical, but would like your opinions/facts.
I already did it once with no affect (not measured, but driveability wise)
Old Dec 8, 2009 | 05:28 AM
He is saying, Its ok to do it if you doing an alignment afterwards.
I did it myself couple of times, my alignment is still ok. but I dont do it anymore cuz its a bitch to reach the front cross member.
Old Dec 8, 2009 | 09:47 AM
kster's Avatar
That's hard to believe as well. It if required a new wheel alignment afterwards, it would say so in the service manual.
In my other RWD cars (s2k, miata, m3) I never had an alignment change after jacking from the front cross-member.
Old Dec 8, 2009 | 09:49 AM
Huey52's Avatar
Registered Zoom Zoomer
You need a very low profile jack to reach the front crossmember point, or drive up on some sections of 2x6. You shouldn't adversely affect your alignment.
http://www.hi-impact.org/ryang/modif...ackpoints.html
Old Dec 8, 2009 | 03:56 PM
TrochoidMagic's Avatar
is adjusting valve lash
off topic...
but in ur attachments, those seems like the revised undertrays that improves drag a bitr on the newer models... it seems like it can also fit the S1 models to me, but i can be wrong.
Old Dec 9, 2009 | 02:15 AM
ClarityMD's Avatar
FYI original poster here...
I use a costco aluminum jack, easily gets to the center crossmember no problem. And the jack pad is about 5" diameter.
Maybe jacking from the crossmember with one of those puny Craftsman mini "2 ton" jacks?
RXFEVER
Aug 29, 2018 10:14 AM
Jelliott5384
Oct 26, 2016 05:15 PM
RXFEVER
Sep 11, 2016 02:51 PM
chadsta
Sep 20, 2015 11:00 PM
jtdwab
Sep 12, 2015 04:57 PM
